Suspension & Brakes Theory, alignment, spring rates....
Is this BRAND NEW Ground Control spring OK to use?
Old Aug 24, 2006 | 01:02 PM
Fuster_Cluck's Avatar
Default Is this BRAND NEW Ground Control spring OK to use?
I have a new set of Ground Control coilovers that I plan to install this coming Monday. Something I noticed with one of the springs.
At one end of the spring the coil is welded to the spring/coil. At the other end at the same location there is a small gap between the end of the coil/spring and the coil it's very close too. All 4 springs are like this.
When all 4 springs are laid out with the spring rate / Eibach lettering facing the same direction one spring is laying the opposite way.
Should I install the spring with the lettering facing right way up or (lettering) upside down so the spring matches the other 3?
Modified by Hybrid93Hatch at 9:33 AM 8/25/2006
Old Aug 24, 2006 | 01:04 PM
Tyson's Avatar
Default Re: Is this BRAND NEW Ground Control spring OK to use? (Hybrid93Hatch)
hmm... yeah, id really be interested in pics. seems like they ghetto rigged the spring rate higher.
it wouldnt matter if it was upside down or not tho.
Old Aug 24, 2006 | 01:10 PM
Default Re: Is this BRAND NEW Ground Control spring OK to use? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">hmm... yeah, id really be interested in pics. seems like they ghetto rigged the spring rate higher.
it wouldnt matter if it was upside down or not tho.</TD></TR></TABLE>
They are custom spring rates 450f/500r.
So, is one end of the coil supposed to be attached (welded) to the spring?
I may have to contact Ground Control about this
Old Aug 24, 2006 | 01:12 PM
Tyson's Avatar
wait, are these new?
are the ends just touching? or really welded??
Old Aug 24, 2006 | 01:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">wait, are these new?</TD></TR></TABLE>
Brand new from Ground Control
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">are the ends just touching? or really welded??</TD></TR></TABLE>
One end is welded (not much weld just enough to keep the attachment. The other end is not/1-2mm gap.
Old Aug 24, 2006 | 02:08 PM
Tyson's Avatar
ah, then i wouldnt worry about it at all. im still curious to see the welded end. im kinda skeptical it really is. the ones with gaps are going to compress and touch anyway its not an issue.
Old Aug 24, 2006 | 02:27 PM
vtecvoodoo's Avatar
Future Texas Boy
It's not welded..LOL. Probably just extra powder in that area.
Old Aug 24, 2006 | 02:28 PM
PIC Performance's Avatar
edit: yeah what he said.
Modified by PIC Performance at 5:27 PM 8/24/2006
Old Aug 24, 2006 | 05:09 PM
Default Re: Is this BRAND NEW Ground Control spring OK to use? (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">It's not welded..LOL. Probably just extra powder in that area.</TD></TR></TABLE>
I'll look again tonight and see if I can pull them apart for verification
Old Aug 25, 2006 | 05:35 AM
Pic posted. I tried to run easy glide dental floss between the connection with no luck. Is the spring ok?
Does it matter which side is upright with the installation?
Old Aug 25, 2006 | 06:37 AM
vtecvoodoo's Avatar
Future Texas Boy
It's just coating. The spring is fine.
Old Aug 25, 2006 | 08:37 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">It's just coating. The spring is fine.</TD></TR></TABLE>
yeah, what he said...
that aint a weld...
Old Aug 25, 2006 | 09:40 AM
ewaugh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">yeah, what he said...
that aint a weld... </TD></TR></TABLE>
I also agree. Just paint.
Old Aug 25, 2006 | 10:40 AM
Default Re: Is this BRAND NEW Ground Control spring OK to use? (ewaugh)
Now to finalize this thread:
Does it matter which way the spring is installed? Stamp/writing right side up? If I keep all 4 with the writing up right then the one spring will actually be upside down....
Thanks for all the help!!
Old Aug 25, 2006 | 10:56 AM
Tyson's Avatar
Old Aug 26, 2006 | 09:05 AM
projectTeG's Avatar
i was gonna say it looks like it sealed up from the powdercoating. welds dont look that clean
Old Aug 26, 2006 | 09:16 AM
Function7's Avatar
Looks like a blob of extra powedercoating. They are safe and fine to use.
-A
Old Aug 27, 2006 | 01:55 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Is this BRAND NEW Ground Control spring OK to use? (Function7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Now to finalize this thread:
Thanks for all the help!!</TD></TR></TABLE>
I'd have to look at mine again, but I don't think it matters. Do the letters facing the right way.
CAN97SH
Suspension & Brakes
Dec 28, 2008 02:16 PM
dirrrtykorean
Suspension & Brakes
Sep 3, 2008 05:34 AM
96 SOHC VTEC
Mar 30, 2003 10:17 AM
InstantRamen
Aug 10, 2001 10:02 PM
