5th Gen Prelude seats into a 4th Gen - HOW TO
Old Aug 24, 2006 | 09:24 AM
MadCityLude
Guest
Posts: n/a
Default 5th Gen Prelude seats into a 4th Gen - HOW TO
Well I have had alot of people asking me how I put my 5th gen seats into my 92 Prelude S. So I thought I might as well do a write up so everyone knows. The reason I did this is because I couldn't find any nice 4th gen seats locally and I was able to get these for about 1/3 the cost of getting some decent 4th gens shipped to me.
Now obviously I used stock seats from a 99 Lude but this also means you could probably use any seat designed for the 5th gen as well.
Now I know my car is extremely messy and dirty, but ignore that for now. It is temporarly out of commision while I track down my fuel problem.
This is the drivers front left bolt (lines up perfectly and used OEM bolt)
This is the drivers front right bolt (again line up perfectly and used OEM bolt)
And the drivers rear left bolt - this one took a little modification to get to work. All I did was get a allen head bolt from fastenal with the same thread as the OEM bolt that the head fit inside the rail and a small washer. Drilled a whole through the rail and tightened the bolt. FYI - When I tightened this bolt tight my rail was a little sticky in this area for a while. It probably tweaked the rail form slightly. After a couple weeks of use sliding the seat forward and back it works great now.
And finally the drivers rear right bolt - this one wasn't quite as clean. I wanted to do like the rear right bolt and use an allen head, but the rail assembly lined up in a way that wouldn't allow it. So I just simply drilled a small hole in the floorboard. I used fender washers and locknuts on the bottom, then sprayed it with spray on truck bed liner as a rust preventative.
Repeat for the passenger side - it all works the same way.
Overall this was an easy mod-install that really didn't take much longer than a typical seat swap.
If anyone does this would they please post the sizes of the bolts and washers they used for future reference. Otherwise I will be pulling my seats soon for black carpet install and I will check mine then.
If anyone has any questions, comment, concerns just ask.
Modified by MadCityLude at 1:20 PM 8/24/2006
Old Aug 24, 2006 | 09:27 AM
bb_one's Avatar
Default Re: 5th Gen Prelude seats into a 4th Gen - HOW TO (MadCityLude)
Good write up ! This should be included in the FAQ.
Old Aug 24, 2006 | 09:29 AM
MadCityLude
Guest
Posts: n/a
Default Re: 5th Gen Prelude seats into a 4th Gen - HOW TO (bb_one)
Thank you, I did this almost two years ago and just finally did the write-up. I use HT all the time to get info and help, I figured it was about time I contribute something.
Old Aug 24, 2006 | 09:46 AM
VtecFreePrelude's Avatar
pics of them in the car?
so we can see the finished product
Old Aug 24, 2006 | 10:17 AM
MadCityLude
Guest
Posts: n/a
Default Re: (VtecFreePrelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecFreePrelude &raquo;</TD></TR><TR><TD CLASS="quote">pics of them in the car?
so we can see the finished product</TD></TR></TABLE>
No problem. Here you go. Again ignore the mess. And the pictures didn't turn out all that great either.
Old Aug 24, 2006 | 10:31 AM
optikal_blitz's Avatar
good work!
Old Aug 24, 2006 | 10:49 AM
john d
Guest
Posts: n/a
if anyone wants some mint condition 5th gen front+rear seats i have some for sale. 10/10 condition
Old Aug 24, 2006 | 10:52 AM
soundbomber's Avatar
Default Re: 5th Gen Prelude seats into a 4th Gen - HOW TO (john d)
awesome write up
Old Aug 24, 2006 | 11:40 AM
MadCityLude
Guest
Posts: n/a
Default Re: 5th Gen Prelude seats into a 4th Gen - HOW TO (soundbomber)
^^ Thank you
Old Aug 24, 2006 | 11:53 AM
daoshao's Avatar
nice info....so 5th gen seats are an option then....wonder if 5th gen rears fit?
Old Aug 24, 2006 | 12:02 PM
MadCityLude
Guest
Posts: n/a
Default Re: (daoshao)
I haven't tried, but I kind of doubt it. The pics I have seen of them make them appear to be quite different from the 4th gens. I wouldn't mind trying though.
Old Aug 24, 2006 | 12:46 PM
sherman's Avatar
Default Re: (MadCityLude)
Can you not swap the rails from 4th gen seats? Atleast it would prevent drilling the rails and the floor board.
Old Aug 24, 2006 | 12:54 PM
.BigSexy's Avatar
most hood white kid
what about doing a console conversion write up Derek?
Old Aug 24, 2006 | 03:05 PM
MadCityLude
Guest
Posts: n/a
Default Re: (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">what about doing a console conversion write up Derek? </TD></TR></TABLE>
I will, but there was a little more too that, and I am fixing my car today
Old Aug 24, 2006 | 03:07 PM
MadCityLude
Guest
Posts: n/a
Default Re: (sherman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sherman &raquo;</TD></TR><TR><TD CLASS="quote">Can you not swap the rails from 4th gen seats? Atleast it would prevent drilling the rails and the floor board. </TD></TR></TABLE>
When I bought the seats that was my plan, but it turned out not to be possible. They mount totally different.
Old Aug 28, 2006 | 08:53 AM
ill45's Avatar
Good write up... now vacum them carpets
Old Aug 28, 2006 | 01:36 PM
ninja 6's Avatar
Default Re: 5th Gen Prelude seats into a 4th Gen - HOW TO (ill45)
picking up a baby from the backseat of a prelude is a nightmare.
Old Aug 28, 2006 | 02:26 PM
SnlpeR's Avatar
to me personally...
the 5th gen seats are less convenient because they dont have the releaser towards the top of the seat back like the 4th gens do
if you have a low 5th gen and throw stuff in the rear seat you know what im talking about..
the only releaser is the handle on the side unlike the 4th gens with both handle on the side and upper side
Old Aug 28, 2006 | 02:28 PM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill45 &raquo;</TD></TR><TR><TD CLASS="quote">Good write up... now vacum them carpets </TD></TR></TABLE>
x2 hehehe but seriously nice write up
Old Aug 28, 2006 | 02:34 PM
Wsteun's Avatar
Nice work but why would you swap 5G seats into a 4G? 5th gen seats suck ***.
Old Aug 28, 2006 | 02:47 PM
98vtec's Avatar
moderator emeritus
Default Re: (Wsteun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wsteun &raquo;</TD></TR><TR><TD CLASS="quote">Nice work but why would you swap 5G seats into a 4G? 5th gen seats suck ***.</TD></TR></TABLE>
agreed. I hate mine. No lower back support and the butt pad is practically non-existent.
Old Aug 28, 2006 | 03:45 PM
MadCityLude
Guest
Posts: n/a
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude &raquo;</TD></TR><TR><TD CLASS="quote">Well I have had alot of people asking me how I put my 5th gen seats into my 92 Prelude S. So I thought I might as well do a write up so everyone knows. The reason I did this is because I couldn't find any nice 4th gen seats locally and I was able to get these for about 1/3 the cost of getting some decent 4th gens shipped to me.
But in all actuality, the ride comfort is about equal. I guess given my 4th gens were pretty worn out though its prolly not a fair comparison. but I will say the way the 4th gen seats somewhat wrapped around my lower back was kinda nice.
Sk8erlude
May 9, 2007 10:44 AM
hozn
Mar 14, 2006 11:53 AM
ItalynStylion
Nov 7, 2004 01:55 PM
GAccord
Sep 11, 2004 09:28 AM
red_sir
12
Aug 18, 2002 01:19 PM
