Knock sensor wirring info
Old Aug 24, 2006 | 08:11 AM
wheeleg6's Avatar
Default Knock sensor wirring info
If i am using a gsr engine harness for my92 cx h22, being as though the gsr harness has a knock sensor will i still have to wire it directly to the ecu. Also I needed to know if i am using the gsr harness will i have to change injector clips to the prelude clips the harness is obd1
Thanks
Old Aug 24, 2006 | 06:36 PM
poison's Avatar
Default Re: Knock sensor wirring info (wheeleg6)
Yes correct. You will still need to wire it from the Knock sensor to the D3 pinout.
Old Aug 25, 2006 | 01:30 AM
HondaPartsHero's Avatar
Technical Hero
Yes you will have to wire it from the sensor to the ECU. Also if your H22 is OBD2 you will have to change over the injector clips from OBD1 to 2
jdm_sai
Jul 18, 2010 06:05 AM
jdmcraig
Nov 17, 2005 03:30 PM
. o 69 o .
Apr 19, 2004 04:26 PM
TurBoTeG
Jan 15, 2004 05:16 PM
importneeds
Feb 15, 2002 01:47 AM
