Best Oil?
Guest
Posts: n/a
What is the best oil to use on my integra? What is the best brand, weight, changing interval? I currentlyuse 5w-30, and a Fram Filter. I change the oil every 3,000 miles. I plan on using Mobil 1 5w-30 and a Fram filter. I heard you can keep synthetic oil longer than conventional motor oil.
Choice oil for my car is only royal purple 5w30, although I'd only use it on a motor with low miles, its so slick that it tends to let loose a lot of build up in the motor which in turn can cause some blocked leaks if non synthetic has been used for a while.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom »</TD></TR><TR><TD CLASS="quote">I run Mobil 1 synthetic 5w-30. I prefer the oem Honda filter, or the Hamp filter.</TD></TR></TABLE>
