B16 Swap Problems
yo wats up
I got a 96 civic sedan lx...
Me and My friend just put a b16 in it...Im having problems with getting the key out...could it be that the car was automatic before?
Also the tachometer is not workin... I dont know how many miles per hour im going nor i know how many rpms im shifting in...what could that be...
And the last thing is the radiator fan is not workin... Please Help out...Thank u..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Z3120 »</TD></TR><TR><TD CLASS="quote">It would help if you could tell us what gen is the B16, what ECU, wiring harness, conversion from auto to manual, etc..
My bad
Its a 99 ob2 b16, with the 99 si ecu, and the 99 si wiring harness, and yes it was a conversion from auto to manual...
I hope thats enough..
Please Help
My bad
Please Help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGwhat!!! »</TD></TR><TR><TD CLASS="quote">have you tried turning the steering wheel while trying to get the keys out</TD></TR></TABLE>
yea i've tried that already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by el negro »</TD></TR><TR><TD CLASS="quote">
My bad
Please Help
I thought that once u unplugg the 99-00 ECU it doesnt work b cus of the anti theft system or something. i read it on the HONDA ENGINE SWAPS book. they reccommend you avoid this ECU and use the JDM computer. im not exaclty sure dont quote me on this but i sounds right?
that might b one of the problems hope it helps
My bad
Please Help
</TD></TR></TABLE>I thought that once u unplugg the 99-00 ECU it doesnt work b cus of the anti theft system or something. i read it on the HONDA ENGINE SWAPS book. they reccommend you avoid this ECU and use the JDM computer. im not exaclty sure dont quote me on this but i sounds right?
this won't work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Frijoles »</TD></TR><TR><TD CLASS="quote">
I thought that once u unplugg the 99-00 ECU it doesnt work b cus of the anti theft system or something. i read it on the HONDA ENGINE SWAPS book. they reccommend you avoid this ECU and use the JDM computer. im not exaclty sure dont quote me on this but i sounds right? that might b one of the problems hope it helps</TD></TR></TABLE>
neither will this because it has nothing to do with the ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by el negro »</TD></TR><TR><TD CLASS="quote">thanks man ill find out if its that.. </TD></TR></TABLE>
what you have to do is look for the 2 thickest wires running to the center console, where the auto shifter was. the wires are black, and one has a red stripe the other has a white. you need to cut them and connect them together and the keys will come out.
this won't work.
[/QUOTE]
Thanks man
...sounds like it happened to you
...i will do this asap just to get the key out...but i still got other problems...
[/QUOTE]Thanks man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
Yes, tricking the car in to park. In an automatic trans car, the only time you can pull out the key, is when the car in PARK. Philosofy1 is correct.
</TD></TR></TABLE>Yes, tricking the car in to park. In an automatic trans car, the only time you can pull out the key, is when the car in PARK. Philosofy1 is correct.
civicdozer
Engine Management and Tuning
Jul 22, 2010 08:23 AM
ef dino
Jul 11, 2006 08:51 PM
