Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
random question...
Old Aug 23, 2006 | 08:12 PM
iwantspeed's Avatar
Default random question...
why does my car alarm warning chirp go off when a frekin airplane fly's over?? its rEALLY annoying at night. i have to get up at like 3 oclock and walk to the car turn off the alarm lock door with key and have no alarm just manual locked doors. that or just unlock the car from my room in my warm BED that i dont want to get out of, and let it sit fully unlocked. ( just to keep that damn warning chirp to stop)
sooooo..... does anyone know how to fix this problem
p.s. i have NO clue where to look to find out what kind of alarm i have. as i bought the car used
Old Aug 23, 2006 | 08:22 PM
Miracle's Avatar
Default Re: random question... (iwantspeed)
It goes off because of either the "shockwave" as the plane goes over, or the sounds of the plane itself.
Only way to disable it is to remove the shock sensor on the aftermarket alarm to disable it.
Old Aug 23, 2006 | 08:23 PM
iwantspeed's Avatar
Default Re: random question... (.Red.EM2)
o common red tell me HOW to remove it
Old Aug 23, 2006 | 08:24 PM
Miracle's Avatar
I dont know, I have never been too good with aftermarket alarms. I have installed stereos before, but never alarms.
You may be able to find help in the Audio/Video/Security forums too.
Old Aug 23, 2006 | 08:25 PM
iwantspeed's Avatar
lol thanks anyways. your the HONDA guru not aftermarket alarms guru.
Old Aug 23, 2006 | 08:36 PM
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwantspeed &raquo;</TD></TR><TR><TD CLASS="quote">your the HONDA guru...</TD></TR></TABLE>
Eh, you may have conflicting arguments about that.
I am by no means a guru of anything, I know just enough to get me by, or get me killed, one of the two.
Old Aug 23, 2006 | 08:38 PM
iwantspeed's Avatar
haha. but u do have an answer for everything.. besides this..
Old Aug 23, 2006 | 08:59 PM
Vantage's Avatar
is it aftermarket or OEM alarm. i find a lot of lower end alarms have CHEAP shock sensors, and have almost anything set them off.
Old Aug 23, 2006 | 09:04 PM
iwantspeed's Avatar
Default Re: (B18a_CRX)
its not stock. i dont think stock ones come with that do they?
Old Aug 23, 2006 | 09:08 PM
toyomatt84's Avatar
Sanji
Default Re: (iwantspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwantspeed &raquo;</TD></TR><TR><TD CLASS="quote">its not stock. i dont think stock ones come with that do they? </TD></TR></TABLE>
There's an alarm for our cars stock. But I doubt the sensors for it would be tripped so easily. You might want to see if the power connections to the alarm can be disconnected from the battery. Or take it to a car electronics place and have them inspect it.
Old Aug 24, 2006 | 04:04 AM
fventura03's Avatar
your car must be stock, i'd be afraid to leave it unarmed overnight. i rather wake up and know its a plane then anything else.
what alarm is it? it might have some type of sensitivity controller that you can adjust.
Old Aug 24, 2006 | 07:09 AM
iwantspeed's Avatar
Default Re: (fventura03)
no my cars not stock on the inside thats why im so paranoid. prolly 4 grand worth of stuff in it lol
Old Aug 24, 2006 | 07:16 AM
skipbarber's Avatar
honda factory alarms dont have shock sensors. if you can locate your shock sensor, it has a sensitivity adjustment, turn it down.
Old Aug 24, 2006 | 07:20 AM
iwantspeed's Avatar
i just took apart the thing under the steering wheel and found a little black box that says on guard crime stopper but there was no *** to turn the sensitivaty down...
Old Aug 24, 2006 | 07:29 AM
Curiouz_G's Avatar
i found out that the viper alarms are the ones that are the most snesitive to noise and sound when i use to work at best buy.
Old Aug 24, 2006 | 07:39 AM
iwantspeed's Avatar
Default Re: (Curiouz_G)
where would u install the shock sensor?
Old Aug 24, 2006 | 12:43 PM
skipbarber's Avatar
youre looking for a small black box that only has one, 2-4 wire plug going into it. sometimes it's labeled, sometimes it's not. in some cases, if it doesnt have a ****, it'll have a small trim pot like youd see on a circuit board, youll need a small screwdriver to turn it down.
Old Aug 24, 2006 | 03:40 PM
Curiouz_G's Avatar
i never said i installed them . but everytime they finished a install, lets just say i would know also my friends have viper alarms on their car. all i had to do was sit next to them, take it to 5k and it would go off.
Old Aug 24, 2006 | 05:54 PM
AiL45's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwantspeed &raquo;</TD></TR><TR><TD CLASS="quote">no my cars not stock on the inside thats why im so paranoid. prolly 4 grand worth of stuff in it lol </TD></TR></TABLE>
if your paranoid like i was then go n get yourself a new alarm, i personally like clifford, and get yourself door looks if yours are manual like mine where. once you do that, trust me you will feel really relieved that you have a good alarm, never worry if you locked your doors, and wont have to hear the alarm wake you up because of a plane and i know the plane wont set it off, because i work RIGHT next to an airport and my car NEVER goes off when a plane flies by.
gaaray2k
Acura TSX
May 12, 2009 07:28 AM
iwantspeed
Audio / Security / Video
Aug 24, 2006 08:20 AM
vandeec5
Feb 25, 2004 07:36 PM
eg686
10
Mar 25, 2003 02:26 PM
CereaLand
Mar 5, 2003 10:33 PM
