help car won't start after swap
Old Aug 23, 2006 | 08:05 PM
stp_vtec_boi's Avatar
Default help car won't start after swap
okay i just got done swapping a gsr to my ls and it wont start both motors are OBD1. it cranks but won't turn over... i recheck all wires and they are all plugged in....sounds like a distributor to me.i changed spark plugs and wires already..please help
Old Aug 23, 2006 | 08:06 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: help car won't start after swap (stp_vtec_boi)
Very may well be the dizzy.
92DAIntegraXSI's Avatar
do you have spark and fuel?
Old Aug 23, 2006 | 08:11 PM
Default Re: help car won't start after swap (92DAIntegraXSI)
i havent check the fuel but do you ghuys think its any of the ground wires but im leanning towards the dizzy..plus how do u check for fuel sorry but trying to be safe at the same time..
Old Aug 23, 2006 | 08:48 PM
GoldCoin's Avatar
dam same problem as me yo . i replaced my dizer and it worked for like a day or day . then it started messing up again . im also tryin to figure it out. i sent mine to the shop and the mechanic said the compression was off and it also could be fuel is not coming into the valves. ive also been hearing that i might not have compression and imma needa change the valve and stuff. so imma be following this tread as well .
bump this shet up there-
Old Aug 23, 2006 | 08:50 PM
Default Re: help car won't start after swap (DC TWOin IT)
do you guys know what goes out in the dizzy that i might need to replace or should i just buy a brand new one..
Old Aug 23, 2006 | 08:53 PM
94_DC4's Avatar
The harness isn't damaged right? Check for fuel, spark, and the timing. Make sure the tensioner is tight as well that is what f***'d my friends swap.
Old Aug 23, 2006 | 08:54 PM
GoldCoin's Avatar
the coil maybe.
Old Aug 23, 2006 | 09:01 PM
how much is it for a replacement of the coil.
Old Aug 23, 2006 | 09:06 PM
GoldCoin's Avatar
well on my LS the coil that was in there is the same as a 2000 civic ex coil . so for your gsr maybe a 2000 si coil might be the same. there is a number on the coil that might match to another coil from a diffrent car. but if there is none i say a coil from junkyard runs for around 60. i dont know how much it is new.
hayn_integra
Oct 23, 2007 10:09 AM
turbotime
Dec 7, 2006 12:48 PM
93h22a1vtec
Jun 3, 2006 07:47 AM
xerox445
36
Mar 1, 2004 08:59 AM
[626]95-GSR
30
Feb 16, 2002 12:06 PM
