Fuel Regarding Topic-Compression
Old Aug 23, 2006 | 07:12 PM
GoldCoin's Avatar
Default Fuel Regarding Topic-Compression
i just remembered that the mechanic said fuel is not coming into the valves . so how much is a fuel pump be for a 94 LS be? and could that really be the problem?
Old Aug 23, 2006 | 07:30 PM
bluemax189's Avatar
Default Re: Fuel Regarding Topic-Compression (DC TWOin IT)
could also be clogged injectors a bad fuse or relay or even heard of loose wiring and connections.
Old Aug 23, 2006 | 07:35 PM
GoldCoin's Avatar
Default Re: Fuel Regarding Topic-Compression (bluemax189)
those things getting fixed shouldnt cost as much as a new fuel pump or anything ?
and having those problems can make your car not start?
Old Aug 23, 2006 | 08:55 PM
GoldCoin's Avatar
bumpers
input help plz
Old Aug 23, 2006 | 09:12 PM
Dartanian's Avatar
If it is the fuel pump (which I seriously doubt), a Walbro 190lph pump can be purchased on ebay for less than $100 and installed by any retarded monkey with hand tools.
Again, I seriously doubt fuel is the problem. First, check the ignition components, then run a compression test, then go on to troubleshooting the fuel system.
Cameron60
Jan 16, 2007 06:04 PM
crexSIvtec
Mar 5, 2005 05:10 AM
Z6REX-SI
10
Mar 9, 2004 07:50 AM
SLOW4drINTEG
Jul 30, 2003 07:09 AM
