GSR ecu question
Old Aug 23, 2006 | 07:53 PM
nuklang's Avatar
Default GSR ecu question
Is it the same thing between the 97 gsr ecu and the 00 ecu. like plug and play
i know for the 00 i need to take out the immobilizer.
Old Aug 23, 2006 | 07:56 PM
lVlemphizStylez's Avatar
Default Re: GSR ecu question (nuklang)
no its not plug and play
Old Aug 23, 2006 | 07:57 PM
92DAIntegraXSI's Avatar
why would u need to take out the immoblizer? it is its own seperate thinglocated under the dash not part of the ecu. but as far as them being the same compare the plugs. i dont really remember if there is a difference on the outside but as far is the maps and stuff they should be the same.
Old Aug 23, 2006 | 07:58 PM
Default Re: GSR ecu question (92DAIntegraXSI)
different external plugs
Old Aug 23, 2006 | 08:00 PM
Default Re: GSR ecu question (lVlemphizStylez)
different pulgs as far as wat OBD2a and OBDb right?
Old Aug 23, 2006 | 08:01 PM
yes
Old Aug 23, 2006 | 09:14 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">different external plugs</TD></TR></TABLE>
The immobilizer is the least of your worries. The ECU won't plug in unless you have an OBD2a to OBD2b conversion harness.
Old Aug 24, 2006 | 09:17 AM
95dc2teg's Avatar
Default Re: GSR ecu question (Sleeper Style)
Thank god i have OBD1. OBD2's are a pain the *** with their OBD2a OBD2b OBD2c OBD2d OBD2e etc. (jk)
Old Aug 24, 2006 | 09:21 AM
Lauj87's Avatar
Default Re: GSR ecu question (95dc2teg)
yeah it's not plug and play. for one 97 is OBD2a and 99-01 are OBD2b. Plugs are different and not to mention immobilizer. that would mean you would have to get a chipped key and a 99-01 ignition.
SCMFOX
Oct 7, 2018 03:51 AM
magic hat #9
Nov 4, 2004 09:01 AM
Vera
Oct 2, 2004 03:32 PM
nutsack
Oct 28, 2003 10:38 PM
mickey513
Apr 8, 2002 07:59 PM
