ls-vtec rev limit?
Old Aug 23, 2006 | 07:30 PM
champLSinteg's Avatar
Default ls-vtec rev limit?
How high can I rev safely on a ls block with forged rods and piston but stock sleeves? I am putting in some buddy club valve springs and retainers up top.
Old Aug 23, 2006 | 07:39 PM
GoldCoin's Avatar
Default Re: ls-vtec rev limit? (champLSinteg)
iono to tell you the truth but on choosing lsv. **** is fast. i used to have that in my car. i took it up to 9k one time. but every other time i took it to 8.2
Old Aug 23, 2006 | 07:43 PM
Default Re: ls-vtec rev limit? (DC TWOin IT)
Yeah. I have my rev limit set at 8200 and take it there sometimes. I am rebuilding the block and upgrading the head so I want to rev much higher.
Old Aug 23, 2006 | 07:48 PM
GoldCoin's Avatar
what kind of ecu are you running?
Old Aug 23, 2006 | 09:36 PM
Fat Chick Magnet's Avatar
Old Aug 23, 2006 | 09:39 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by champLSinteg &raquo;</TD></TR><TR><TD CLASS="quote">How high can I rev safely on a ls block with forged rods and piston but stock sleeves? I am putting in some buddy club valve springs and retainers up top.</TD></TR></TABLE>
Wherever you stop making power. But since you have stock cams, 8200 is fine.
Old Aug 23, 2006 | 09:48 PM
GoldCoin's Avatar
Default Re: (dc2rtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek &raquo;</TD></TR><TR><TD CLASS="quote">8200-8500.</TD></TR></TABLE>
i agree. about the same.
Old Aug 23, 2006 | 09:55 PM
Lauj87's Avatar
yeah i'd say around 8200rpms too...is your car tuned?..if not once you do get it tuned just look at the dyno graph and see where you car stops making power...and just take it a couple hundred of RPM's over.....
Old Aug 24, 2006 | 09:30 AM
Default Re: (Lauj87)
I forgot to mention that it will be boosted and looking for around 300whp. If it still wants to make power around 9k will I be fine taking it there?
Old Aug 24, 2006 | 09:37 AM
Lauj87's Avatar
Default Re: (champLSinteg)
humm in that case i would say no. untill you get the crank balanced i don't think it's safe to bring above 9k.
Old Aug 24, 2006 | 10:29 AM
chu77's Avatar
What about the bearings? will they be fine?
Old Aug 24, 2006 | 10:59 AM
Lauj87's Avatar
im sure they should be okay
Old Aug 24, 2006 | 11:48 AM
NAmodified's Avatar
wat about redline ona a b18b stock block with a itr head?
Old Aug 24, 2006 | 12:38 PM
VTECth1s's Avatar
Default Re: ls-vtec rev limit? (NAmodified)
the ITR head can withstand more then 8k rpm on a stock valvetrain, the B18B stock block can hold up to around 7-7400k rpm i think, correct me if im wrong. Just because the head can rev high doesnt mean the block can hold up to it as well. The block can fail first before the head. build the block up first then the head. I suggest upgrading the pistons, connecting rods, bearings..etc, sleeving it possibly, then you can rev up to 9 at least, but most important is the tune and builder if you want longevity and reliability.
Modified by egg6vtak at 1:50 PM 8/24/2006
Old Aug 24, 2006 | 01:03 PM
PrinceAli132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egg6vtak &raquo;</TD></TR><TR><TD CLASS="quote">the ITR head can withstand more then 8k rpm on a stock valvetrain, the B18B stock block can hold up to around 7-7400k rpm i think, correct me if im wrong. Just because the head can rev high doesnt mean the block can hold up to it as well. The block can fail first before the head. build the block up first then the head. I suggest upgrading the pistons, connecting rods, bearings..etc, sleeving it possibly, then you can rev up to 9 at least, but most important is the tune and builder if you want longevity and reliability.
Modified by egg6vtak at 1:50 PM 8/24/2006</TD></TR></TABLE>
DO NOT REV A STOCK B18B BLOCK TO 8000.
The stock rod bolts can not handle it and will come loose and really mess **** up. The stock rod bolts are known to warp and get all screwed up. If you want to rev higher i would highly suggest replacing the stock rod bolts with some ARP rod bolts.
Ali
Old Aug 24, 2006 | 11:28 PM
95 integra's Avatar
Default Re: ls-vtec rev limit? (PrinceAli132)
Mine held to 8500+ just fine (please note, the guy asked about a built block and Im telling him about my built block....so no f'ing bs about "A stock block cant"...it wasnt stock and your dumbass didnt read). Basically it all depends on how well the engine is assemblied and if you got the bearing specs right.
Old Aug 25, 2006 | 12:13 AM
jdm_bones's Avatar
When, first built my LSV set up, I had a stock LS block with ARP studs and rod bolts...I have an ITR head with P73 ecu...And I would take it to 8400 no problem...but I'd also say 8200 is safe!
Old Aug 25, 2006 | 07:45 PM
aafryf's Avatar
Default Re: ls-vtec rev limit? (jdm_bones)
I have kept mine well past 9K... its yours do what you want...
Old Aug 25, 2006 | 09:07 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: ls-vtec rev limit? (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote"> (please note, the guy asked about a built block and Im telling him about my built block....so no f'ing bs about "A stock block cant"...it wasnt stock and your dumbass didnt read). </TD></TR></TABLE>
How are Forged rods/pistons going to make it safer to rev higher?
When that's all he said was in his "built" block..
Old Aug 26, 2006 | 07:36 AM
vtec-gorilla's Avatar
Default Re: ls-vtec rev limit? (CleanLikeJdm)
what really helps u rev to 8k on ls vtec is it the connecting rods that u have to replace or u can just get away with putting in arp rod bolts?
BoostModeCivic
Oct 7, 2013 10:04 AM
nengx07
22
Feb 8, 2009 06:40 PM
175Shot4Door
Aug 22, 2006 07:44 PM
type B16
Aug 20, 2006 11:41 AM
ophdehEEzY
12
Dec 30, 2003 11:37 AM
