Oil in spark plug cylinder
This is my moms car. She drives a 95 Accord LX auto car has 59k on it. I was changing her plugs,cap, rotor, wires and i noticed oil on the cap. The oil was only on the cap not inside. Then i went to change the plugs and in cylinder #3 i found oil sitting in there. The other cylinders were fine though. Any ideas what the problem may be ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 »</TD></TR><TR><TD CLASS="quote">Most likely it is the spark plug seal under the valve cover worn out.</TD></TR></TABLE>
sounds about right
sounds about right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH »</TD></TR><TR><TD CLASS="quote">yea thats what i was thinking also. Any other ideas ? Because i found oil on the cap also ? Valve cover gasket ? </TD></TR></TABLE>
valve cover gasket is another good point
my car had a bad valve cover gasket and i had oil on my spark plugs.
Yes, it could be that simple. Most times, unfortunatly, it isn't (orings under the rockerarm assembly). Check this link out. And good luck.
http://www.cb7tuner.com/vbb/sh...seals
There are other links too, if you decide to change them yourself (orings).
premo_si
Jan 23, 2008 08:57 PM
honda-1919
Nov 18, 2007 06:00 PM
chrimy90cx
15
Dec 23, 2006 08:48 AM
JDM-EJ1
15
Nov 17, 2004 05:32 PM
screech
Jul 13, 2003 12:44 PM
