whats up with my tranny need help asap
Alright will im in the process of finishing the swap and some how i can't put in the passenger axle. I looked in the tranny and it looks like theirs a pin in the tranny that wouldn't let the axle go in please i need help asap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez »</TD></TR><TR><TD CLASS="quote">are you talking about the differential?? thats normal and wont prevent you from putting in the axle</TD></TR></TABLE>
I dont know but it wont go in and doesnt pop in ..i tried wiggling it and no luck should i pop it in as much as it can go and then just put it in the caliper or should i try to push it all the way in...
youre supposed to find where the axle keys into the tranny...itll like slide twist and lock but you gotta find the spot where itll slide easily in rotate as youre trying to put it in
it helps the have someone tap on the end of the axle with a hammer while you wiggle it and it should slide right into place
I actually jusy put one in yerturday
keep trying at it...dont be afraid to give it some muscle...just use some discretion when you should realize its not gonna fit in that way
undertheradar
10
Aug 21, 2006 07:17 AM
Sketch_hs
10
May 27, 2004 08:13 PM
