Shif Linkage Removal
Old Aug 23, 2006 | 01:05 PM
beoy9's Avatar
Default Shif Linkage Removal
Hey guys, I'm going to be taking my shift linkage out tonite, but I have a couple questions.
The 8 mm spring pin, is it 8mm wide? or is it 8 mm long? Confused about that. And does it go through the retainer as well?
Also, about the circled green part, I'm using the helms manual for everything, but what exactly does 8 x 1.25 mm mean as far as the bolt or nut is concerned?
Thanks for all your help.
Modified by beoy9 at 4:37 PM 8/23/2006
Old Aug 23, 2006 | 01:14 PM
B16b-EJ8's Avatar
Default Re: Shif Linkage Removal (beoy9)
Im sure if you searched for "shift linkage" you would find tons of info...but here is a link to get you started.
https://honda-tech.com/zerothread?id=1641621
Old Aug 23, 2006 | 01:21 PM
philosofy1's Avatar
just wondering, why are you taking it out?
Old Aug 23, 2006 | 02:09 PM
B16b-EJ8's Avatar
^^also a good question
Old Aug 23, 2006 | 02:38 PM
beoy9's Avatar
Default Re: (B16b-EJ8)
Fixed the img, but I'm taking it out to put the GSR one in that is coming with my B18C. =]
Old Aug 23, 2006 | 02:42 PM
ProJectCvic's Avatar
Default Re: (beoy9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beoy9 &raquo;</TD></TR><TR><TD CLASS="quote">Fixed the img, but I'm taking it out to put the GSR one in that is coming with my B18C. =]</TD></TR></TABLE>
use one of your ac compressor bolt.
Old Aug 23, 2006 | 02:46 PM
beoy9's Avatar
Default Re: (ProJectCvic)
I don't have AC, but use it for what?
Old Aug 23, 2006 | 02:51 PM
B16b-EJ8's Avatar
Default Re: (beoy9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beoy9 &raquo;</TD></TR><TR><TD CLASS="quote">I don't have AC, but use it for what?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Im sure if you searched for "shift linkage" you would find tons of info...but here is a link to get you started.
https://honda-tech.com/zerothread?id=1641621</TD></TR></TABLE>
Old Aug 23, 2006 | 02:54 PM
beoy9's Avatar
Oh ****, I forgot to check that out after I fixed my image. &gt;&lt;
Old Aug 23, 2006 | 02:57 PM
88 rex's Avatar
Default Re: (beoy9)
Take it out with it still attached to the transmission. Then worry about getting off of the tranny when you have free room to wack away with a big old hammer. I wouldn't waste my time with that pin while under a car. It will just make you frustrated. They don't call it the "b***h" pin for nothing.
Old Aug 23, 2006 | 03:05 PM
beoy9's Avatar
Default Re: (88 rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">Take it out with it still attached to the transmission. Then worry about getting off of the tranny when you have free room to wack away with a big old hammer. I wouldn't waste my time with that pin while under a car. It will just make you frustrated. They don't call it the "b***h" pin for nothing.</TD></TR></TABLE>
Would you have to unmount the tranny from the block, or will it all come out easily?
Old Aug 23, 2006 | 03:50 PM
strictly.business's Avatar
Banned
tyhe pin is 8 mm wide. the retainer goes over the pin to keep it from ever coming out (lmfao). pull the retainer off, get a 8 mm punch. hammer it the expletive out.
Old Aug 23, 2006 | 03:54 PM
B16CRXT's Avatar
Default Re: (strictly.business)
I never have trouble getting that pin out. I take a normal sized philips screwdriver and a mallet to it and it comes right out after a couple whacks. I do it under the car as well. Removing the transmission to remove the shift linkage is a lot more work than is required.
Old Aug 23, 2006 | 04:21 PM
StolenTeg's Avatar
Default Re: (B16CRXT)
Take it off the tranmission first, i take 2 off and put 1 on today. Take a few minute of hitting it and seem like it not coming out but it will come out when dont expect it to
Old Aug 23, 2006 | 04:26 PM
beoy9's Avatar
Thanks for your help guys. Also in that other thread where they were talking about using the AC mounting bolts, do you think my engine has the bolts even though there is no AC? If not, are there some other bolts in the engine that are tapered like those?
Old Aug 23, 2006 | 05:43 PM
Ej1_coupe's Avatar
Default Re: (beoy9)
that pin is cake, I went to most auto stores looking for an 8mm pin punch, but no one had it, so I took a phillips head screwdriver.. and a hammer, and got the pin out with no problem.
Old Aug 23, 2006 | 08:07 PM
88 rex's Avatar
Default Re: (beoy9)
Would you have to unmount the tranny from the block, or will it all come out easily?</TD></TR></TABLE>
When I pulled my motor, I pulled the motor and tranny out together with the linkage still attached. I took a few whacks at it and couldn't get an leverage to get a good shot at it. And the air hammer was a pain to use upside down under a car with little room. I have a nice random bolt lying around that is 8 mm wide and works like a charm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote"> Removing the transmission to remove the shift linkage is a lot more work than is required. </TD></TR></TABLE>
Agreed, but he is pulling his motor and tranny for a B series. I would never go through the hastle of pulling the tranny just to pull hte linkage. I can't really think of any reason other than to pull your motor/tranny that you would need to take that pin out.
Old Aug 23, 2006 | 11:13 PM
beoy9's Avatar
Well I got the ****** out, and I realized right at the end why it's called the bitch pin. Not because it's a bitch, no no, but because instinctivly the first thing you say when it goes flying around the garage is "****** Bitch!"
haha
I ended up breaking a shitty nut driver apart just to get to the shaft to get it out, the screwdriver thing just seemed to spread the bottom out and it got stuck.
Old Aug 23, 2006 | 11:56 PM
axtran's Avatar
easiest method was to use an A/C compressor to bracket bolt, which has a tapered end and is the perfect size to remove it.
Old Aug 24, 2006 | 01:17 AM
lv6l's Avatar
some pb blaster and a 8mm punch from habor freight did the job in 10 seconds.
Old Aug 24, 2006 | 05:03 AM
philosofy1's Avatar
Default Re: (beoy9)
so your doing a swap? if that's the case, you don't even have to remove it. have someone go under the car and feed it through as the engine is being lowered into the bay. cake!
Old Aug 24, 2006 | 12:59 PM
88 rex's Avatar
Default Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
so your doing a swap? if that's the case, you don't even have to remove it. have someone go under the car and feed it through as the engine is being lowered into the bay. cake! </TD></TR></TABLE>
bingo
Harman07
Honda Civic (2006 - 2015)
56
Nov 22, 2007 07:08 PM
NguyenDC2
Jun 22, 2007 11:47 AM
spiderhatch
Apr 27, 2007 02:28 PM
atsyuo
Aug 24, 2005 11:43 AM
EliteCivicX
12
Feb 18, 2005 10:25 PM
