Help.....Where is shift linkage?
ok....so i need to ****** get this bitch pin out.............i am told the ****** linkage is near tranny....i dont see **** where the **** the pin would be. i got helms, and couldnt find where the page was for "where to remove it". i need to remove it so i can do something else im working on.
any help for the location..... i know where the rods are that come from the shifter then go to the tranny but i just maybe am missing this ****...........(96 coupe)
Re: Help.....Where is shift linkage? (EliteCivicX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EliteCivicX »</TD></TR><TR><TD CLASS="quote">thanks that did exactly the job!!</TD></TR></TABLE>
No problem...That website is very useful...save it in your favorites for future references.
Re: Help.....Where is shift linkage? (gabebauman)
You need an 8mm rolled pin punch... I have never seen one in a store, I ordered a pair from McMaster carr a while back ($$$ )
Re: Help.....Where is shift linkage? (.RJ)
Whats the difference between a rolled pin punch and a regular 'ol punch? I just use a regular type 8mm Craftsman punch when I take mine out.
TSPeed Factory
Re: Help.....Where is shift linkage? (Honda Hick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Hick »</TD></TR><TR><TD CLASS="quote"> I just use a regular type 8mm Craftsman punch when I take mine out.</TD></TR></TABLE>
works everytime
works everytime
right now i have a bolt just about the same size of the hole going through there with a nut on top and the shifter wiggles like crazy. Does the spring pin expand in the hole or ?????.... tryin to see if i can find something else that works the same, otherwise i'll order it from that site above
Re: Help.....Where is shift linkage? (BDogggUT34)
craftsman actually has the rollpin punch. but you have to buy the whole set. its like 19bux at sears. and its not measured in metric, which you have to use the 1/4". + if you use this, I think you can safely remove the bitch pin without mushrooming it, then reuse it so it pays for having this tool I guess.
