Gear Question
Old Aug 23, 2006 | 11:07 AM
9hatch6's Avatar
Default Gear Question
my 4th gear syncros are shot, goes in gear, cant give it the gas....do u know if syncro mesh would work, or do i need to get 4th syncros switched out?
Old Aug 23, 2006 | 11:09 AM
LowSlow93Sol's Avatar
Default Re: Gear Question (crashcars)
More details as to what is happening when you shift to 4th?
Old Aug 23, 2006 | 11:10 AM
9hatch6's Avatar
Default Re: Gear Question (LowSlow93Sol)
i shift to 4th, give it the gas, pops right out. i mean i can down shift from 5th to 4th and it stays, but as soon as i give it gas, it pops out
Old Aug 23, 2006 | 11:15 AM
Default Re: Gear Question (xjerseyhate)
That sounds like a bigger problem than just syncros. If you keep your hand on the shifter when you gently get on the gas is if forced out of gear? or does it just slip out?
Old Aug 23, 2006 | 11:21 AM
9hatch6's Avatar
it like just slips out, and it'll make the grind sound
Old Aug 23, 2006 | 11:47 AM
2nd has done that to me a couple of times and I figured that I didnt get it in gear all the way. if your syncros were bad you would have trouble getting the tranny to shift INTO 4th, not slipping out.
Old Aug 23, 2006 | 11:50 AM
The only thing that I can think of is that 4th gear itself may be worn. Does it do it every time?
Old Aug 23, 2006 | 11:58 AM
**DOHC HaTcH**'s Avatar
Its your gear. You must have been grinding your 4th gear a lot. Becuz wat happens is when you grind your gear, the synchro tries to lock on but really its just chipping away at your gear. Then the next time you put it into 4th correctly the synchro cant lock on thus creating it to slip or pop out. Looks like your gonna need a tranny rebuild. sorry if the explanation is unclear.
Old Aug 23, 2006 | 01:35 PM
9hatch6's Avatar
Default Re: Gear Question (**DOHC HaTcH**)
is a transmission place able to fix a worn down gear? or is not even worth it?
Old Aug 23, 2006 | 01:40 PM
9hatch6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LowSlow93Sol &raquo;</TD></TR><TR><TD CLASS="quote">The only thing that I can think of is that 4th gear itself may be worn. Does it do it every time?</TD></TR></TABLE>
yeah does it everytime
Old Aug 28, 2006 | 06:03 AM
The only way to fix a worn gear is to replace it. get a quote at a trannmission shop and then find out how much it would be to get a good used tranny. I say this b/c if you have a Dseries you can probably get a good used tranny for less than the cost of rebuilding the one you have.
Renanv206
Apr 2, 2019 12:18 PM
snzh22
Dec 9, 2006 08:20 PM
torr
May 22, 2005 03:49 PM
missinghubcabs
Jun 25, 2003 03:41 PM
b20civic
Dec 2, 2002 05:28 PM
