quick Q what brake lines for EK w/integra fronts
i have a 97 civic hb dx with integra front brakes bolted on. but i cant get the stock brakes lines to fit properly. which brake lines are you guys using? integra brake lines? integra ones seem a little too long.
i got a set of 99-00 techna-fit stainless brake lines and they dont fit at all! they are either to short or to long however you run them, or rubbing the shock body. also the tab mount for the brake line on the integra spindle has 2 holes and the tab on the si lines has 1 hole. nothing works properly, the ek lines are to short, and the integra lines are way to long, what lines did you guys use? Any pictures of 99-00 si OEM lines?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer »</TD></TR><TR><TD CLASS="quote"> Any pictures of 99-00 si OEM lines?</TD></TR></TABLE>
try ebay
Rock the Si lines, all the cool kids are doing it.
try ebay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer »</TD></TR><TR><TD CLASS="quote">up again for pics of the 99-00 si lines</TD></TR></TABLE>
Do you honestly have any need for a picture of the brake lines?
Their beauty isn't anything to write home about.
I bet google has a picture of some cars brake lines, which I bet look similar to Si lines, if you just need an Idea.
On the contrary, http://www.comptechusa.com/sto...t.jpg
yes I HONESTLY DO, i want to see how the oem mounting bracket looks. if you dont have a picture dont reply. Did you even read the whole thread or just assuming thigns? I see you obviously have not used 99-00 si lines with 94+ integra spindles...
none of my lines have a straight pipe coming off where the banjo bolts to the caliper, they are at like 45 degree angles
elnoyl
May 6, 2009 05:38 PM
TrboInteg
Jan 15, 2008 10:37 AM
dingle
Nov 15, 2005 08:33 PM
Incubus05
Nov 10, 2003 08:23 PM
