EK disc brake conversion(which lines do i need)
I am swapping 96 civic drums with 99 gsr discs. I read the archives about if u use the integra calipers u have to use the integra lines, is that correct?
Is there more than one main brake line on each side or is there a couple of brake lines on each side? Which ones do i need? The conversion doesn't come with the lines!!
I use the 99-00 si e-brake cables correct?
Re: EK disc brake conversion(which lines do i need) (dingle)
There is only 1 line on each side.
and yes, you would use the 99-00 Si e-brake cables.
-edit- Sorry, I just went over the thread in the FAQ. Sorry for the misinformation, it looks like you would need the Integra rear brake line.
Modified by 2000DX at 11:40 PM 11/15/2005
Re: EK disc brake conversion(which lines do i need) (2000DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000DX »</TD></TR><TR><TD CLASS="quote">You would use the 99-00 Si rear brake line. There is only 1 line on each side.
and yes, you would use the 99-00 Si e-brake cables.</TD></TR></TABLE>
What he said!
What he said!
In the faq's archive it says that the lines on an si will not work on integra calipers because the ends on them are different?
Correct!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dingle »</TD></TR><TR><TD CLASS="quote">In the faq's archive it says that the lines on an si will not work on integra calipers because the ends on them are different?</TD></TR></TABLE>
What year Si?
Correct!!
What year Si?
elnoyl
05-06-2009 05:38 PM
01geeser
10
03-26-2007 05:05 PM
jdmxGod
08-21-2005 10:25 AM
