Tranny Help....
Old Aug 23, 2006 | 10:10 AM
^AnDre^'s Avatar
Default Tranny Help....
Ok heres my delema.
I have a EF for the track and it has a JDM b16b engine (with a spare b18b pushing 144 hp and 124 ft/lbs) and coupled up to that is a JDM YS1 trany with stock lsd. Is there any transmission with better suited gearing for the track preferable in cable, or in hydro. In hydro, what would be the best trany for this package?
Old Aug 23, 2006 | 10:48 AM
TwoRedEGgs's Avatar
Default Re: Tranny Help.... (^AnDre^)
Well here are the gear ratios for a cable b16;
3.307
2.105
1.458
1.107
0.875 (final drive 4.4)
And these are some hydro ratios !!
98 Spec JDM R tranny
3.23
2.105
1.458
1.036
0.787 (final drive 4.78)
96Spec JDM R
3.23
2.105
1.458
1.036
0.787 (final drive 4.4)
GSR S80 tranny
3.23
1.9
1.36
1.034
I'm pretty sure that these are correct so your ratios are pretty good for the track right now !!
Modified by TwoRedEGgs at 1:10 PM 8/23/2006
Old Aug 23, 2006 | 11:34 AM
WWDTrackRacer's Avatar
New User
Default you have the "best" already
YS1 has the shortest 5th gear. Woot.
Umm... if its still not short enough its time to start thinking about a final drive swap. 4.7 or 4.9. Lots to choose from.
Old Aug 23, 2006 | 12:31 PM
^AnDre^'s Avatar
Default Re: you have the "best" already (WWDTrackRacer)
yeah an FD swap would be awsome.. but I have yet to find one for a b16 cable trany, all are for hydro and clearly state that.
Old Aug 23, 2006 | 01:55 PM
thawley's Avatar
Default Re: you have the "best" already (^AnDre^)
You've already got the most desirable cable trans there is. Different final drive is your only move up...
Old Aug 23, 2006 | 03:04 PM
88 rex's Avatar
Default Re: you have the "best" already (thawley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley &raquo;</TD></TR><TR><TD CLASS="quote">You've already got the most desirable cable trans there is. Different final drive is your only move up...</TD></TR></TABLE>
x2
Or go hydro and then drop in a 4.7/4.9 fd.
Old Aug 23, 2006 | 03:20 PM
New User
Default dont like your YS1? Give it to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^AnDre^ &raquo;</TD></TR><TR><TD CLASS="quote">yeah an FD swap would be awsome.. but I have yet to find one for a b16 cable trany, all are for hydro and clearly state that. </TD></TR></TABLE>
You know cable trannies came before hydro. YS1 was the first trans to receive the new updated internals. So it's a mistake to call something only "hydro" tranny compatible. And it's a mistake to say YS1 is hydro compatible. It is the the hydro trannies that are 2nd generation cable compatible.
If you don't want your YS1. I'll relieve it off your hands.
Old Aug 24, 2006 | 04:56 AM
^AnDre^'s Avatar
Default Re: dont like your YS1? Give it to me. (WWDTrackRacer)
ok... forget i said anything about that transmission...
i am talking about my car being compliant with a hydro tranny. I am looking to pick up a hydro trany and put the following gears in it:
1st - 3.077
2nd - 2.10
3rd - 1.652
4th - 1.308
5th - 1.033
FD - either 4.4, 4.78, or 4.928
and looking to keep my YS1 as a spare. My question to you guys is how can I convert my car which came with a Cable trany to work with a Hydro transmisison, and how well does it work. And then the next question would be, what would be the best Hydro trany to get (as a spare) to work with the JDM b16b.
Old Aug 24, 2006 | 01:08 PM
88 rex's Avatar
Default Re: dont like your YS1? Give it to me. (^AnDre^)
What mounts do you have?
I don't think the cable trannies work with certain hydro mounts, but I could be all wrong. If that's the case then you would need a different tranny mount. You will also have to drill out the rear tranny bracket to accept the larger bolts for the hydro tranny...not that big of a deal, just something to note.
In any case, I would sell that cable if you are going hydro and pick up a spare hydro sometime in the future. Why do you need a spare anyway? Is this a track car?
I personally like my USDM ITR/96+ spec ITR/CTR ( ) with the JDM 4.785. I mostly drive on the streets and it's perfect for me. I don't think I would ever go back to a 4.4 final drive. If it were a track only car, or if you are brave enough, I could definitely see getting the 4.9 very appealing.
An LSD is also a bonus to have
Old Aug 24, 2006 | 01:30 PM
^AnDre^'s Avatar
Default Re: dont like your YS1? Give it to me. (88 rex)
that would be most likly the scenario.. getting rid of the cable tranny in opt for a hydro. The car is a track only car and definatly not road legal. the YS1 has a lsd in it, and I have a ATS Carbon LSD which is sitting on my garage floor which should have fit, but due to some misscomunication, it dosent ; (... I have the option of picking up a b16a2 hydro trany with ATS Metal D20 lsd. and would probally pick that up and after I blow out a gear, upgrade it to the following close gear ratios:
1st - 3.077
2nd - 2.10
3rd - 1.652
4th - 1.308
5th - 1.033
my main question is still the reliablity and strength of the swap. Will it hold up to pure track driving. Or am i just stuck with the cable and paying through the nose when I rebuild it (it was just rebuilt FYI and has only 10 laps on it... would have been more but had electrical problems and we shut down)..
Old Aug 24, 2006 | 06:18 PM
88 rex's Avatar
It should be just as strong as any other ITR/Si tranny out there. There are plenty of them getting tracked all the time, and I'd guess the only wear item would be synchros and an occasional bearing. Other than that It won't be any weaker/stronger than your current tranny. The advantage is finding parts for the hydro or just a replacement.
Old Aug 28, 2006 | 04:30 AM
^AnDre^'s Avatar
What about the actual mounts then?
Old Aug 29, 2006 | 04:07 AM
New User
Default What are you trying to achieve?
You realize the YS1 is the predecessor to the "ITR" gearbox?
Technically the S1 was the first "ITR" gearbox.
If all you want to do is add a final drive / LSD to the YS1 it can be done.
Please describe details / PM and I will straighten out your confusion.
In the meantime read these:
https://honda-tech.com/zerothread/1649302
http://hybrids.jp/forum/showthread.php?t=21540
Good luck
Old Aug 31, 2006 | 05:16 AM
^AnDre^'s Avatar
Default Re: What are you trying to achieve? (WWDTrackRacer)
How can you add in a FD into a YS1? i thought it was not possible.
gilou bilou
Jan 12, 2015 03:07 PM
mrx
18
Feb 25, 2013 05:21 AM
^AnDre^
Apr 6, 2005 06:14 PM
DJCujo69
Aug 12, 2003 09:08 AM
da6vtec
Dec 23, 2001 06:19 AM
