hello everyone!!!- couple of technical questions-
Old Aug 23, 2006 | 07:06 AM
lbstyling's Avatar
Default hello everyone!!!- couple of technical questions-
hello people!
Im new to the forum- fresh from the rtoc (Renault Turbo Owners Club). Ihave owned a prelude vtec for a year now as a road car, recently the car was written off (rear ended!) so the engine is intact but the rest of the car is mashed.
Thats a little background for you which may help to explane my questions-
1- could i fit my t2/t25 hybrid turbotecnics to my prelude engine?- it can run 25 psi - however the 2.5 inch compressor wheel is tiny compaired to the t3/t4 turbos that seam to be the normal option, ok im sure its possible- but is it worth it??
secondly i was very interested in mounting the head off my h22 to a h23 bottom end- but is that a good idea if im running a turbo??
Any help would be hugely appreciated!!!!!
Thanks!
Old Aug 23, 2006 | 07:10 AM
MadCityLude
Guest
Posts: n/a
Default Re: hello everyone!!!- couple of technical questions- (lbstyling)
If you are gonna do a frankenstein boost motor, go with the F22 botom end for its iron sleeves.
Old Aug 23, 2006 | 07:16 AM
Lewdin' Incognito's Avatar
IMO, anything over 5-7psi on stock internals is asking for problems (boom!). If you do go turbo, I would stick with either a complete H23 or the F22 bottom end, what MadCityLude said.
The Frankenstein builds (h22 head on h23 block, etc.) are toward the bottom of the Prelude FAQ page - posted at top of main Prelude page.
Old Aug 23, 2006 | 07:27 AM
lbstyling's Avatar
Default Re: hello everyone!!!- couple of technical questions- (MadCityLude)
great!- just had a look on the search- sounds like the f23 is what im after- what about oil injectors? on a h23 i know you need to fit the oil injectors to cool/lube the bottom end because the h23 isnt designed to rev high- do you still need this on the f23? and can it be fitted??- iron bottom end is awsome!!!! heavy but awsome!
street_ride14
Jun 27, 2009 10:52 AM
james9761217
Aug 14, 2006 04:23 PM
EJ8 GSR-T
35
Sep 6, 2005 03:39 PM
bubs
Apr 2, 2005 04:59 AM
Sleeping4drLS
Dec 1, 2002 05:15 PM
