NEED BEAKS SRK INSTRUCTIONS
Old Aug 23, 2006 | 01:08 AM
Coupe-R's Avatar
Default NEED BEAKS SRK INSTRUCTIONS
The links to the pdf instructions on the beaks page isnt working for me
can someone post up thr EG/DC SRK instructions for me please
Old Aug 23, 2006 | 01:21 AM
BlueIntegraBoy's Avatar
Default Re: NEED BEAKS SRK INSTRUCTIONS (Coupe-R)
https://honda-tech.com/zerothread?id=1564967
Old Aug 23, 2006 | 02:58 PM
Coupe-R's Avatar
Default Re: NEED BEAKS SRK INSTRUCTIONS (BlueIntegraBoy)
whats up with drilling another hole right next to the other one
THATS PLANE DODGY
Now does anyone have the actual PDF from beaks?
Old Aug 23, 2006 | 03:21 PM
Heinz57's Avatar
I drilled a hole right next to the existing hole because otherwise the Beaks aluminum reinforcement bracket wouldn't be straight otherwise, and possibly become a stress point..
if you want you can try and fit it with the existing hole, even if it makes the bracket crooked - but at least it won't be "plane dodgy"..
I threw out the instructions that came with the kit. but i followed step by step with the instructions. It also may depend on what model/year civic you have. I don't have abs and whatnot. goodluck.
Old Aug 23, 2006 | 05:02 PM
Coupe-R's Avatar
Default Re: NEED BEAKS SRK INSTRUCTIONS (Heinz57)
All good, yeh with the hole that close to another a stress point is what you should watch out for, it will be weaker in that area.
Anyways so does anyone have a scan of the instructions or PDF file
Old Aug 23, 2006 | 05:31 PM
Heinz57's Avatar
There is enough surface area on the face of the bracket that it covers both holes. plus the fact there's an identical bracket on the other side of the subframe. So in essance the metal of the subframe is sandwiched in between the two beaks brackets.
but anyway, now that i think of it, if you were to have the bracket crooked, you'd also have the hard time of trying to attach the sway bar to the D-brackets parallel to the ground.
bump for someone with a PDF file.
Old Aug 31, 2006 | 04:56 PM
Coupe-R's Avatar
PDF please>?
joprez
Suspension & Brakes
27
May 13, 2012 11:35 AM
X93siX
Aug 4, 2010 12:11 PM
Jonathan_ED3
30
Oct 30, 2004 07:30 PM
beanbag
Jun 19, 2004 09:20 AM
GSRrR
Jun 28, 2003 10:26 PM
