will 98+ spec JDM Type R axels, half shaft, motor mounts and engine harness fit on my 99-00 Si ?
Old Aug 22, 2006 | 09:03 PM
alien's Avatar
Default will 98+ spec JDM Type R axels, half shaft, motor mounts and engine harness fit on my 99-00 Si ?
just wanted to know if these parts will all bolt on to my Si .. some say axels harness half shaft nor the motor mounts will fit.. some say i only need two si motor mounts ..
Old Aug 23, 2006 | 05:53 AM
slowcivic2k's Avatar
Default Re: will 98+ spec JDM Type R axels, half shaft, motor mounts and engine harness fit on my 99-00 Si ?
you will need to replace the hubs, or if they hubs arent interchangeable, the front knuckles from a ITR to fit the axles in your civic, the ITR mounts I beleve will not work, the Si mounts will, they HAVE to be Si mounts, or else the rear mount will not bolt up. and the typeR is obd2a I beleive, and that is hell to install a wire harness anyways just make it an OBD1 motor and be done with it.
Old Aug 23, 2006 | 08:52 AM
double post, whoops
rick_rabies
Honda Civic (2006 - 2015)
Mar 29, 2018 12:37 PM
wiz321654
Sep 7, 2010 10:16 AM
1sikhatch
May 16, 2007 04:18 AM
hypedlunatic
Oct 31, 2004 12:19 PM
