Stripped Allen Key/Hex Bolt
Old Aug 22, 2006 | 08:39 PM
a1320addict's Avatar
Default Stripped Allen Key/Hex Bolt
Had to replace a 14mm with a allen key/hex bolt for clearance reasons. When attempting to remove it, the hex slot stripped.
I wanted to know if anyone had any tricks on removing something like this? I'm a little wary on using an EZ-Out as I've had bad luck with them in the past. Only thing I can think of is grinding two parallel cuts and using an adjustable wrench.
TIA
Old Aug 23, 2006 | 09:21 AM
Default Re: Stripped Allen Key/Hex Bolt (a1320addict)
anyone?
Old Aug 23, 2006 | 10:38 AM
dat_flip's Avatar
Depending on how much room you have I would try and chisle or cut slots on the head of the bolt. Then use an impact driver with a flat tip screwdriver bit to break it loose then just use a flat tip screwdriver to take the rest of it off. Or you can chisle a slot on the bolt head and use a punch to spin it out. Or you can try left hand drill bits. Or use easy outs. Like I said it all depends on how much room you have to work with.
Old Aug 23, 2006 | 01:59 PM
Default Re: Stripped Allen Key/Hex Bolt (dat_flip)
Thanks for the input. Gave the Bolt-Out from Craftsman a shot and it worked without a hitch
Old Aug 26, 2006 | 05:19 PM
boostedblkef's Avatar
channel locks
joevtoo
Jul 3, 2014 04:45 PM
acmoc
13
Dec 20, 2008 11:12 AM
Btothe3rdDegree
20
Jan 23, 2005 01:36 PM
is3oo
Oct 4, 2003 01:48 PM
hellas
Jan 21, 2003 12:33 PM
