How Long Before your ISB Went out??
Just woundering, since my single cam tranny is making this noise, and I pin pointed it to be the Input shaft Bearing. Mide you the noise goes away for a sec and sounds nice then comes back quick
Just wanted to know how long your tranny lasted making that scary noise before it went to crap??
Thanks...
Thanks...
it depends, its a bearing so depending on how the car is driven. if the car gets ripped from a stop very often, drag raced, shifted hard it will wear alot faster.
Under normal conditions, ive seen them last for the useful life of the car
my 94 ex coupe had over 300,000 miles on the same transmission, never skipped a beat..
well, until my mom drove it overheated and the engine seized, but other then that it was great!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TorquelessB16 »</TD></TR><TR><TD CLASS="quote">WTF is an ISB? </TD></TR></TABLE>
lol 200 and somethin posts and you dont know what an isb is?? thats....sad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ci_v_ic »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>I'm sure there are quite a few members here that could embarras you with your high and mighty 200 posts.
Shut up.
Mine never went. I put almost 4k on the tranny AFTER I heard it, and never had it go on me, but I don't know that I'd recommend it. If the bearing does lose the cage, you're into a full tranny rebuild then.
</TD></TR></TABLE>I'm sure there are quite a few members here that could embarras you with your high and mighty 200 posts.Shut up.
humm...I just want me this tranny to last till tax time
then ill sell the car, they'll swap a B in it, and we're all happy.
the tranny does shifts nice though, just that damn noise, makes me nervous.
when I cruise on the high way or stay at a constant speed, I wont hear it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">I'm sure there are quite a few members here that could embarras you with your high and mighty 200 posts.
Shut up.
Mine never went. I put almost 4k on the tranny AFTER I heard it, and never had it go on me, but I don't know that I'd recommend it. If the bearing does lose the cage, you're into a full tranny rebuild then.</TD></TR></TABLE>
blow me ****** mcfaggerton. ive been a member since since 02, but i got banned for making one post about a ******* alternative fuel.
i dont know what the hell that was about but i would shut the expletive up if i was you. your name says it all dude nothing else needed.
end yourself.
Shut up.
i dont know what the hell that was about but i would shut the expletive up if i was you. your name says it all dude nothing else needed. end yourself.
end yourself.
Yea that was realllllyy smart.
youre a god damn idiot....
to the thread starter:
My friends has been making that noise for a couple of months, and he drives it to and from school probably 2 times a month(180 miles each direction). mine hasnt gone yet, and i hope it dosent. ive got 93K on mine.
end yourself.
And you're banned agian.
</TD></TR></TABLE>And you're banned agian.
Like Ricey said, I had one make noise for about 3 years and counting, to this day it still shifts like butta!! I sold the car to my buddy and he's to lazy to fix it.
took mine out of service after about 20k on a noisy isb tore the trans apart to overhaul found a lot of fillings on the magnet checked all the specs on things every thing checked okay just fragments from the isb replaced it and all is good. So a lot of it is just luck on how long things will hold together
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 »</TD></TR><TR><TD CLASS="quote">took mine out of service after about 20k on a noisy isb tore the trans apart to overhaul found a lot of fillings on the magnet checked all the specs on things every thing checked okay just fragments from the isb replaced it and all is good. So a lot of it is just luck on how long things will hold together</TD></TR></TABLE>
bits and pieces
well, poor car...besides that noise, I just found out I may be running on 3 cylinders
no wounder this bitch bearly holes idle.
feel like setting this thing on fire
bits and pieces
eg6turb0
Mar 1, 2005 07:33 PM
