double flare tool
Old Aug 22, 2006 | 08:46 AM
redboost10's Avatar
Default double flare tool
for those of you who have relocated or redid your brake lines, did you use a metric double flaring tool? if so, where did you get it? im having trouble looking for one. thank you. or does the standard 3/16" flare get the job done?
Old Aug 22, 2006 | 09:28 AM
skunked's Avatar
Default Re: double flare tool (tgh99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">for those of you who have relocated or redid your brake lines, did you use a metric double flaring tool? if so, where did you get it? im having trouble looking for one. thank you. or does the standard 3/16" flare get the job done?</TD></TR></TABLE>
standard worked fine for me.
Old Aug 22, 2006 | 11:21 AM
redboost10's Avatar
Default Re: double flare tool (skunked)
ok cool, i just wasnt too confident using standard flaring tool
Old Aug 22, 2006 | 11:28 PM
Hondoctors's Avatar
Double flare tool works better. It doesn't make the end of the line split like the single flare does. You can get it from Matco...or, I'm sure you can find one on SJ discout tools website too.
Old Aug 23, 2006 | 04:17 AM
jjspec's Avatar
Default Re: (Hondoctors)
You can find them at Lowes, Home Depot, or any hardware store. You should always double flare brake lines.
Old Aug 23, 2006 | 06:15 AM
redboost10's Avatar
Default Re: (jjspec)
i was using a double flaring tool, i wanted to know if anyone has used the standard 3/16" instead of buying a metric sized one. i would never use a single flaring tool
Old Aug 23, 2006 | 06:55 AM
skunked's Avatar
Default Re: (tgh99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">i was using a double flaring tool, i wanted to know if anyone has used the standard 3/16" instead of buying a metric sized one. i would never use a single flaring tool</TD></TR></TABLE>
I only use a double flare as well, and yes SAE works fine. All my brake/clutch hardlines are done this way.
Old Aug 23, 2006 | 07:56 AM
redboost10's Avatar
alright, thank you skunked
Old Aug 23, 2006 | 04:34 PM
b18ccivics's Avatar
i tried a standard one it didnt work, but maybe i was doing it wrong, but i decided to go stainless so 37 degree will do t for me
Lateralus_EG
Jun 20, 2008 08:24 AM
86mmboosted_da
Dec 10, 2007 09:54 AM
jdm_dc_199
Sep 10, 2007 11:31 PM
navin
Nov 24, 2003 06:36 PM
