misfire
Old Aug 21, 2006 | 10:47 PM
ridin98civic's Avatar
Default misfire
had a guy read my check engine light, said cyl. 3 misfire. happened right after i put in a stage 2 cam. anyone know what could be the problem. engine runs fine and cant hear any misfires. anyway to reset the ecu to see if it will come on again?
Default Re: misfire (ridin98civic)
oh yea its a d16y8 in a 98 ex
Old Aug 22, 2006 | 02:01 PM
slammedEM1Si's Avatar
does your CEL flash @ any point?
Old Aug 22, 2006 | 02:35 PM
Default Re: (slammedEM1Si)
no it just stays solid
Old Aug 22, 2006 | 04:05 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">had a guy read my check engine light, said cyl. 3 misfire. happened right after i put in a stage 2 cam. anyone know what could be the problem. engine runs fine and cant hear any misfires. anyway to reset the ecu to see if it will come on again?</TD></TR></TABLE>
Read your spark plugs and make sure they are burning stoich. If there is no sign of misfire, I would just try resetting the ECU and see if it comes on again.
Old Aug 22, 2006 | 08:07 PM
spark plugs are good, wires are good, pretty sure the dizzy is good, i dont know how to reset the ecu unless thats what i tried by unhooking the ground for 45 minutes (heard that from soemone)
Old Aug 23, 2006 | 04:42 PM
anybody?
Old Aug 24, 2006 | 06:26 PM
could it be a timing thing, or an incorrectly adjusted valve??
Old Aug 24, 2006 | 06:29 PM
saikouEF8's Avatar
reset the ecu by puling the fuse for like 30 seconds. then put it back. look at the diagram on your under the hood fuse box. its the one that says ECU.
Old Aug 25, 2006 | 04:51 PM
Default Re: misfire (saikouEF8)
thanks ill try that let you know how it goes
Old Aug 26, 2006 | 09:38 PM
there was no ecu labeled fuse under my hood
Old Aug 27, 2006 | 08:48 PM
Old Aug 27, 2006 | 11:22 PM
.Kevin.'s Avatar
you can unplug the battery to reset the ecu. I had this problem in my d16y8 when I put a cam in also. I replaced everything I could from plugs, wires, distributor cap and rotor and I still had the light. It didnt feel differant but the code said it was there and I could hear the popping noise. Well I ended up taking the cam out to sell the car but I never fixed it. What cam are you using?
Old Aug 27, 2006 | 11:33 PM
H-adict's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">there was no ecu labeled fuse under my hood</TD></TR></TABLE>
it should be labeled "back up" in the underhood fuse box......after reseting the ecu,if the cel light still comes on with the same code then try doing a valve adjustment might help.
Old Aug 28, 2006 | 01:09 PM
Default Re: misfire (H-adict)
i am using crower stage 2, with the crower valve spring and retainer kit. i dont plan on selling anytime soon so i would like to fix it. hopefully the valve adjustment will work, or i might just slam my hand under the hood a few times. lol
Old Aug 28, 2006 | 01:12 PM
Evs-One's Avatar
Solbros Owns Me
with a stage 2 cam and OBD2, most likely you will have continuous misfire codes because of the lobes and how it idles.
Go OBD 1 and get it tuned. Make sure alves are adjusted correctly also
Old Aug 28, 2006 | 01:40 PM
Default Re: misfire (Evs-One)
what would be the best way to go obd1? chipped ecu, piggyback?
Old Aug 28, 2006 | 04:22 PM
Evs-One's Avatar
Solbros Owns Me
OBD2 to OBD1 conversion harness and a P28 ecu, then tune it.
My buddy has a 2000 Integra LS with stage 2 cams and SAFC...it's all tuned and makes rediculous torque for the setup, but constantly throws misfire codes- which can be annoying to see a CEL on non stop. Only way to fix this is to go OBD1
Old Aug 28, 2006 | 09:10 PM
do you know where is a good place to order the stuff and what would it most likely cost?
Old Aug 28, 2006 | 09:18 PM
i will probably switch to obd1 if the valve adjustment doesnt work, also never thought about it but could extending the o2 sensor wires so it could fit on lx header make this CEL?
Old Aug 28, 2006 | 10:18 PM
cashshoes's Avatar
i was told you need a adj cam gear when you get a cam because after market cams are a little bigger or something he said but you need a adj cam gear to dial in the correct timming o and also a prob could be spark plugs are gapped to close or to far i am miss firing 2 but mine is in 2,3,and 4 because i have them gapped 2 close
Old Aug 28, 2006 | 10:55 PM
Default Re: (cashshoes)
i dunno, the crower timing guide said all timing aspects should be correct when using stock cam gear. i dunno what my plugs are gapped at guess i could check
project_hatch1.8
Sep 21, 2006 07:43 AM
r1mshady
Jun 27, 2006 05:39 PM
BLACK 00 SI
12
Jan 17, 2004 12:56 AM
Fatty_1775
Jul 10, 2003 10:14 AM
South Bay Surfer
Dec 30, 2002 09:48 PM
