91 octane vs regular
Old Aug 21, 2006 | 09:21 PM
gosu08's Avatar
Default 91 octane vs regular
If i am to run nitrous in my car would i see a performance difference if i were to run 91 octane instead of 87 or 89?
also does higher octane levels make your car run better?
Old Aug 21, 2006 | 10:18 PM
cambopheonix56's Avatar
Default Re: 91 octane vs regular (gosu08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gosu08 &raquo;</TD></TR><TR><TD CLASS="quote">
also does higher octane levels make your car run better?</TD></TR></TABLE>
What motor? If its a stock f22 or f23 then all you need is 87. You can actually hurt performance running 91.
Old Aug 22, 2006 | 04:58 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gosu08 &raquo;</TD></TR><TR><TD CLASS="quote">If i am to run nitrous in my car would i see a performance difference if i were to run 91 octane instead of 87 or 89?</TD></TR></TABLE>
a performance difference? No. but if you run 87 or 89 while spraying your motor won't last long. you have to use premium with any forced induction to avoid detonation.
Old Aug 23, 2006 | 11:32 AM
AdriloverGSR's Avatar
if you run 91, it will be the best bet. you can prevent pre-combustion because that is what 91 really means. The more octane, the more power you'll get due to that your combustion happens at the exact moment it should. If you use nitrous with 87 or 89 your gonna major knock in your engine. This can easily cause you to lose performance and can end up breaking a connecting rod or cracked piston.
924doorEG
14
Jul 11, 2007 12:53 PM
ShadyBAB
13
Apr 2, 2006 10:17 PM
Terrible One
14
May 10, 2005 09:29 AM
goldfinger
Mar 16, 2004 01:00 PM
Mush-
Jul 25, 2003 07:26 PM
