Doing Rear disc conversion on EJ8
sup guys i'm doing a rear disc conversion on my EJ8...the rear disc are off a 94 4door gsr...i need to know if the e brake cable well fit? also do i need all the bolts that bolt up to the trailing arm or can i use my stock ones off my EJ8??Do i need to use the integra LCA's? the brake lines wont work right? i have to get Si brake lines right?
i did an eg8 with a 94gsr rear setup and it went perfect a little remounting and lines worked the stock bolts worked and i used pic lowercontroll arms
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarontrini85 »</TD></TR><TR><TD CLASS="quote">i did an eg8 with a 94gsr rear setup and it went perfect a little remounting and lines worked the stock bolts worked and i used pic lowercontroll arms</TD></TR></TABLE>
pmed you bro...need more info...
Use your stock LCAs. You can use bolts from the Integra or Civic. They are the same. Take the brake lines from the Integra. The ebrake cables should work.
mynameizstitch
10
Dec 13, 2009 03:06 PM
jkinros
May 19, 2008 09:36 AM
