Doing Rear disc conversion on EJ8
sup guys i'm doing a rear disc conversion on my EJ8...the rear disc are off a 94 4door gsr...i need to know if the e brake cable well fit? also do i need all the bolts that bolt up to the trailing arm or can i use my stock ones off my EJ8??Do i need to use the integra LCA's? the brake lines wont work right? i have to get Si brake lines right?
Re: Doing Rear disc conversion on EJ8 (bmoua)
i did an eg8 with a 94gsr rear setup and it went perfect a little remounting and lines worked the stock bolts worked and i used pic lowercontroll arms
Re: Doing Rear disc conversion on EJ8 (aarontrini85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarontrini85 »</TD></TR><TR><TD CLASS="quote">i did an eg8 with a 94gsr rear setup and it went perfect a little remounting and lines worked the stock bolts worked and i used pic lowercontroll arms</TD></TR></TABLE>
pmed you bro...need more info... |
bump
Use your stock LCAs. You can use bolts from the Integra or Civic. They are the same. Take the brake lines from the Integra. The ebrake cables should work.
