Broken water pump bolt!!!! HELP!!!!
Old Aug 21, 2006 | 06:18 PM
DevineEntity's Avatar
Default Broken water pump bolt!!!! HELP!!!!
I have a 95 gsr that needed a new water pump. In the process of placing it back on i over torqued the bolt and it snapped. I tried useing an easy-out. Ruined the bolt. Then tried to retapp the whole with a bigger size bolt and now the new water pump doesnt align..... A friend suggested JB Weld, tried it today and it didnt hold up. Does anyone have a good solution to this problem?
Old Aug 22, 2006 | 12:53 AM
F20Cteg's Avatar
Default Re: Broken water pump bolt!!!! HELP!!!! (DevineEntity)
Drill the hole with the water pump bolted down so it will line up. Then tap it.
Gotta watch out for those 10mm. They will snap really easy if you are not careful.
Old Aug 22, 2006 | 03:46 AM
Default Re: Broken water pump bolt!!!! HELP!!!! (F20Cteg)
thats what i did with the jb weld and it just ate it up. now i have a bigger hole thats out of place
user 23852445234524
Honda CR-V & Element
Apr 16, 2016 05:35 PM
Ran4it2
12
Feb 24, 2009 04:24 PM
syvikraicer
Dec 20, 2006 05:25 PM
abolish415
May 20, 2004 10:36 AM
