D15 build up
Old Apr 26, 2002 | 06:25 AM
blackEF's Avatar
Default D15 build up
Just wondering if anyone has info on a d15 build with y8 head with integra pistons.
Old Apr 26, 2002 | 06:47 AM
MIDNIGHT's Avatar
Default Re: D15 build up (blackEF)
the teg pitson will not work in the d15 due to wrist pin location. the y8 head with a stock d15 piston setup is the way to go. i had a stock d15 with the 6g nonvtec y7 head(wich is for sale) and it took zc powed crx all day long. its a great motor.
Old Apr 26, 2002 | 06:53 AM
blackEF's Avatar
Default Re: D15 build up (MIDNIGHT)
How much hp did you have on your d15 like 140?
Old Apr 26, 2002 | 06:54 AM
WAFFLES's Avatar
he never dynoed or anything, it was all buttdyno. It was a nice motor though.
Old Apr 26, 2002 | 06:57 AM
blackEF's Avatar
Default Re: D15 build up (WAFFLES)
so you have a motor better than the zc for under about 400 bucks?
Old Apr 26, 2002 | 07:05 AM
WAFFLES's Avatar
midnight has all sorts of d series **** laying around his garage. **** he has hella ZC parts for sale I believe.
Old Apr 26, 2002 | 07:09 AM
blackEF's Avatar
so won't zc pistons work? what results would that make?
Old Apr 26, 2002 | 07:11 AM
MIDNIGHT's Avatar
i think so. and you can still get parts for it. unlike the zc. dont get me wrong i loved my zc but i was just surprized at the d15 power i got. this was the setup
d15 shorty
d16y7 non vtec head
clutchmaster stage one
d16a6 intake mani
d16y8 exaust mani with b20 down pipe
zcsi tranny
home made cai
thats it
i used the zc tranny on my d16z6/zc and the d15 and i still think the d15 was just as good as all of those. IMO
Old Apr 26, 2002 | 07:16 AM
blackEF's Avatar
what ecu did you use?
Old Apr 26, 2002 | 07:17 AM
MIDNIGHT's Avatar
from what mista bones has said the piston set realy low in the cylinder and does little to nothing for comprision. and a flat top piston will always have a lower chance of ditonation campared to a dome
Old Apr 26, 2002 | 07:18 AM
MIDNIGHT's Avatar
4g si ecu
Old Apr 26, 2002 | 07:20 AM
blackEF's Avatar
So the y7 head is just like the a6 with higher compression??
Old Apr 26, 2002 | 07:22 AM
MIDNIGHT's Avatar
yes and it flows more and has larger valves than the a6.
Old Apr 26, 2002 | 07:24 AM
blackEF's Avatar
So you don't have to wire for vtec with the y7 so would it be worth it to get the y8 head if its not much more of a hassle??
Old Apr 26, 2002 | 07:27 AM
MIDNIGHT's Avatar
the y8 will give you a higher comp ratio than the y7 due to the square chambers and the vtec will give you a better top end. i just like the simple non vtec approch.
Old Apr 26, 2002 | 07:31 AM
blackEF's Avatar
true that. So would the HF block be fine to use?
Old Apr 26, 2002 | 08:03 AM
MIDNIGHT's Avatar
i guees i alway toss them in the trash our use them as a backup motor. but i would think it would be the same as a dx motor just with 2 valves reliefs on the piston wich mean you gotta swap out piston before you can put a 16v head on
Old Apr 26, 2002 | 08:19 AM
Urban Business
Guest
Posts: n/a
d15 = throws people the **** off when they ask you wtf you have in your car and you reply 1.5L
Old Apr 26, 2002 | 08:35 PM
the DR.'s Avatar
Default Re: D15 build up (TorteX)
right now, i'm in the process of finishing my project. i got the d15 + y8 head (P&P, 3 angle vavle job, .40" milled head, y8 headgasket, d16a6 intake man+TB (match ported to head, CAI, Chikara torque step headers) i got everything for super cheap, and did all the machining(vavles,mill,P&P) myself at school, i'm pretty sure the d15 mini me will smoke alot of cars out there, problem is right now i got an automatic, but have the tranny ready to swap too, i'll let u know how it works out.
Old Apr 27, 2002 | 12:09 AM
Mista Bone's Avatar
D Tranny Guru
yep......
135 hp (118 whp) from a puny 120,000 mile old D15B7
Just easy bolt-ons.
Old Apr 27, 2002 | 09:00 AM
RapeV-8's Avatar
hey midnight i got a 90 dx with a d16 bottom and a d15 top!!! the car runs like **** (cut off at 3600rpm)and i think it is the injector!!! i clean the injector once and it ran good for a week but then it was the same again!!!o yea can u explain what car engine do i get those intake manifold and cams !!! i dont really know what cars and engine u get those item from!?
Old Apr 29, 2002 | 03:33 AM
MIDNIGHT's Avatar
Default Re: D15 build up (igotcrx)
you cut out proplem could be a couple of things. i need more info. as for the parts use pgmi intake manafold from a 88-2000 d16 motor
Old Apr 29, 2002 | 06:39 PM
RapeV-8's Avatar
car cut off at 3800rpm ever gear!!! when i took off the injectors and clean it,it ran find for 2 weeks (cut off at 7500rpm) and it start all over again!!! it have a 1.6 bottom w/ 1.5 dx heads and the rest... i have stock dx ecu on it now
CivicRaping
Jul 25, 2005 04:12 PM
vietnameeh
Apr 3, 2005 04:07 AM
*Boostwerks*
May 1, 2003 02:22 PM
chron1k
Oct 19, 2002 11:31 AM
B16CivicHB
33
Jan 24, 2002 07:21 AM
