cam and cam gear question!
Old Aug 21, 2006 | 12:56 PM
nutball72's Avatar
Default cam and cam gear question!
i have a comp cam 59300, eversince i put it in its idles erratically and has kinda of a lag until around 4k rpms, will the adjustable cam gear help and how do i adjust it?????????? if theres anyone who can help i will give you MAD PROPZ!
Old Aug 21, 2006 | 01:37 PM
BOOSTED RIVAL's Avatar
Default Re: cam and cam gear question! (nutball72)
With a cam gear you could adjust the cam timing for your motor to get the best performance. You could like retard the intake cam a little and test it out if you like it or take it to a dyno for max power for your cam. Cam gear with help alot if you have a after maket cam shaft.
Old Aug 21, 2006 | 01:47 PM
Syndacate's Avatar
Default Re: cam and cam gear question! (BOOSTED RIVAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED RIVAL &raquo;</TD></TR><TR><TD CLASS="quote">With a cam gear you could adjust the cam timing for your motor to get the best performance. You could like retard the intake cam a little and test it out if you like it or take it to a dyno for max power for your cam. Cam gear with help alot if you have a after maket cam shaft.</TD></TR></TABLE>
Yeah, that's probably the problem, it sounds like ur timing is off, the adjustable cam gear will help with that.
EDIT:
Well that's under the crazy assumption it's set right to begin with.
bigsnorlax
Apr 20, 2009 09:18 AM
Boost2NA
Apr 20, 2004 05:47 PM
Mr.Integra
Apr 10, 2003 01:39 PM
