Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Scca Touring class
Old Aug 21, 2006 | 11:51 AM
Fomoco's Avatar
Default Scca Touring class
For scca club racing in the Touring class I was trying to figure out the rule about removing the airconditioning, it seems like you can just pull it out but theres a bunch of stuff about spring rates and roll bars.... i really have no idea why removing a/c would have anything to do with the suspension.
"The factory and/or aftermarket air conditioning system
may be removed, provided that at least the following
items associated with the system are also removed:
compressor, condenser, H.D. radiator, H.D. springs/sway
bars, H.D. shocks, larger tires, engine and transmission
coolers and cooling fans. All duct work, wiring, Freon
lines, valves, evaporators, dryers, and dash controls may
remain. If the air conditioning compressor is an integral
part of the drive system, the compressor may be retained
and disabled."
Old Aug 21, 2006 | 02:50 PM
nonsense's Avatar
Default Re: Scca Touring class (Fomoco)
I'll assume it has to do with cars that have those heavy duty items only when they're equipped with AC. If your car is the same with or w/o AC then it doesn't have HD suspension parts, then it doesn't matter.
But we all know assumption is the mother of all f*ckups, so I'd get an official SCCA answer before you start ripping stuff out.
Old Aug 21, 2006 | 04:27 PM
Fomoco's Avatar
Default Re: Scca Touring class (nonsense)
ok that makes a lot of sense, thanks!
Old Aug 21, 2006 | 09:36 PM
Rene M's Avatar
SCCA... man, they can never make it easy can they..
Old Aug 21, 2006 | 10:08 PM
prkiller's Avatar
Default Re: Scca Touring class (Rene M)
It would help to answer your question if we knew what car specificly you were talking about!
Old Aug 22, 2006 | 12:47 AM
Fomoco's Avatar
Default Re: Scca Touring class (prkiller)
its an integra type r. and the compressor clutch is shot so i want to tear it all out any who.
Old Aug 22, 2006 | 06:52 AM
prkiller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fomoco &raquo;</TD></TR><TR><TD CLASS="quote">its an integra type r. and the compressor clutch is shot so i want to tear it all out any who.</TD></TR></TABLE>
Ahh, well in that case, you may do so from what I read from the rules. Nothing was changed due to the install of the A/C option on the "Type R" , so you can just pull it all out!
Old Aug 22, 2006 | 04:52 PM
slammed_93_hatch's Avatar
wait, sense when was the ITR still allowed to run in T2??
skshow289
Honda Civic (2006 - 2015)
Feb 17, 2018 01:12 PM
marqoid
10
Jun 28, 2013 04:41 PM
///EJ6POWER
Engine Management and Tuning
Jul 20, 2010 06:59 AM
Edwardo911
Aug 18, 2004 10:15 AM
