Rear mounted battery - Alternator noise - Amplifiers
Old Aug 21, 2006 | 08:20 AM
alexdog69's Avatar
Default Rear mounted battery - Alternator noise - Amplifiers
Has anyone experiencing electrical noise problems after moving their battery to the rear?
Any tips? grounding points, etc.?
Old Aug 21, 2006 | 09:54 AM
Tyson's Avatar
Default Re: Rear mounted battery - Alternator noise - Amplifiers (alexdog69)
im no audio guru, but did you separate the audio and power wire paths? my experience is that you cant run power lines next to audio wires. it probably has to do with electrical inductance. signals bleed into each other.
Old Aug 21, 2006 | 10:56 AM
CRXed's Avatar
Default Re: Rear mounted battery - Alternator noise - Amplifiers (Tyson)
I'm having the same problem as well after moving the battery to the rear of my GLC after installing a subwoofer.
Old Aug 21, 2006 | 02:06 PM
saaron34's Avatar
yes, probably the best idea is to run your signal cable on the driver side, and the power cable on the passenger side. Good idea to NOT have the signal wire and power wire on the same side, to avoid electrical noise.
Just have a good, bare metal connection for your ground. Make sure it makes good contact and is tight.
alexdog69
Audio / Security / Video
Aug 21, 2006 08:57 AM
ef u
10
Sep 26, 2005 04:40 PM
Leo95SE
Aug 4, 2003 09:01 PM
AznImage504
Feb 12, 2003 10:36 PM
redblues
Jul 18, 2001 10:45 PM
