DC HEADER MODIFICATION
I was just wondering if the DC header needed to be modified in any way when being installed. I heard that the O2 sensor bung needs to be welded on, just wondering. Thanks!!
my O2 sensor is making my check engine light stay on. did I not put the sensors back in correct or is it just going to be that way regardless of what I do. the check engine light wasn't on originally but it came on about 50 miles after the install
You need to buy an o2 simulator to eliminate the check engine light. Either that or jimmy rig the o2 farther away from the exhaust stream to avoid the CEL.
If you check on Ephatch.com and go to resourses they have a quick easy and cheap way to fix the check engine light my friend did it and it worked. Good Luck
thanks alot man. I'm going to try this tonight hopefully. after i rig it. what should I do to get to CEL to go off? hey 2.0friend, everything for the header came in the box with the header and there was no welding needed. The only thing you'll need to do is rid the second o2 sensor so your check engine light isn't on all the time.
I got a dc race header. I got this o2 simulator
and used that to avoid the check light from going
on. I got the simulator from my mechanic.
The checklight hasn't come on and its been about
a month.
a month.
Wait a min. you are replacing your o2 sensor that is on the header with an o2 simulator?
Isn't this a big NO NO? does the DME read and decide the a/f ratio based on this o2 sensor?
An o2 simulator is basically a resistor that simply sends the signal that the o2 sensor is present. The sime will not monitor EGT which is why i ask about the effects of running the simulator?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wcriot »</TD></TR><TR><TD CLASS="quote">Wait a min. you are replacing your o2 sensor that is on the header with an o2 simulator?
An o2 simulator is basically a resistor that simply sends the signal that the o2 sensor is present. The sime will not monitor EGT which is why i ask about the effects of running the simulator?</TD></TR></TABLE>
I believe what they are talking about is a threaded bung that goes between the o2bung on the header, and the o2sensor. Thus keeping it away from direct airflow from the exhaust. It will still be able to do its thing and sense a/f's its just taking it out of the direct path of the exhaust
ricanzxrebel
May 11, 2007 10:08 PM
Bravenrace
35
Sep 8, 2006 09:33 AM
supapoopa
19
Nov 14, 2005 03:46 PM
KuG
29
Jan 19, 2002 08:36 PM
