tracking down fuel leak...stock fuel pressure info needed
Old Aug 20, 2006 | 05:32 PM
BB6racer's Avatar
Default tracking down fuel leak...stock fuel pressure info needed
anyone know what kind of fuel pressure (psi) numbers should be expected from a pretty stock 5th gen prelude? trying to track down a fuel line leak and i will be installing a gauge to do some monitering, but have no idea what numbers to expect for a normal car. thanks!
Old Aug 21, 2006 | 05:42 PM
BB6racer's Avatar
bump. anyone know???
Old Aug 22, 2006 | 06:12 PM
BB6racer's Avatar
does anyone on here even have a fuel pressure gauge!? or any kind of info/specs on a stock prelude's fuel pressure would be helpful.
Old Aug 22, 2006 | 06:22 PM
v4lu3s's Avatar
RTFM
47-54 psi is the normal range of pressure with stock parts.
Old Aug 22, 2006 | 06:27 PM
A Blue Lude's Avatar
Default Re: tracking down fuel leak...stock fuel pressure info needed (BB6racer)
Helms says 40-47 with the vac line off.
Old Aug 22, 2006 | 09:09 PM
BB6racer's Avatar
coo thanks. i just got the gauge in the mail today and just finished installing it. i got an initial reading of like 45-48 psi from priming the fuel system. but then after the priming stopped, the gauge slowly started dropping down. the last look i got was something like 36-38 psi. I KNEW THERE WAS A LEAK SOMEWHERE! looks like i get to track down a leak after all...
Old Aug 23, 2006 | 09:36 AM
v4lu3s's Avatar
RTFM
you sure that isnt because its equlaizing in teh system? after all once it primes it stops pumping, and the pressur regulator is NOT a closed door type setup. it is a restricted opening based on a certrain level of flow.
hondapowerb16a2
Mar 20, 2010 01:15 AM
karter18
Jul 28, 2007 08:27 AM
Enig
Oct 29, 2004 04:48 AM
integraautox
Nov 30, 2002 10:05 PM
