fmax kit??
Old Apr 25, 2002 | 10:30 PM
viet4gvtec's Avatar
Default fmax kit??
i'm going to get the kit soon just have some ??
1 my car is high mile (170k miles) is it gonna be fine with 8lbs boots or do i have to rebuilt the block
2 if i have to rebuilt the block which do i need (low cr pistons, rods) and what??
Old Apr 27, 2002 | 02:21 PM
CBR's Avatar
CBR
Default Re: fmax kit?? (viet4gvtec)
At 170,000 you're asking for trouble.
Rebuild w/lower compression ratio pistons, that'll help you "tune" the turbo.
Sounds like you need to do a whole lot more researching before you take on this project.
Good luck.
Old Apr 27, 2002 | 04:57 PM
BlueShadow's Avatar
Default Re: fmax kit?? (ChurchBoyRacer)
Rebuild w/lower compression ratio pistons, <U>that'll help you "tune" the turbo.</U>
sounds like you should do your own research as well
Old Apr 27, 2002 | 05:02 PM
BlueShadow's Avatar
It looks like you have a H22A1, and depending on what condition the block is in you might have to replace the block. I dont think you'd have to though.
-cylinders sleeved (Golden Eagle)
-pistons and rings (JE/SRP pistons)
-con-rods (Crower)
-aftermarket radiator (Fluidyne)
you'll probably have to get a lot of the major maintenance items like water pump, and timing belt replaced as well.
EDIT: all that stuff wil allow you to boost more than 8 PSI, just make sure you have a good fuel management system.
[Modified by BlueShadow, 2:04 AM 4/28/2002]
Old Apr 27, 2002 | 06:31 PM
DirtyLude's Avatar
Default Re: fmax kit?? (BlueShadow)
Just a note, but those items that BlueShadow posted are only options and are not necessarily the exact product names you have to go with. I also wouldn't bother with the Fluidyne radiator unless you're doing long track racing events, and I mean seriously long track events.
Remember what BlueShadow mentioned at the end, there's alot of expense in a rebuild that goes into water pump, oil pump, all the gaskets and seals that are needed when rebuilding an engine.
Old Apr 27, 2002 | 06:41 PM
Teen Heartthrob's Avatar
Default Re: fmax kit?? (DirtyLude)
I am in the same boat...albeit i only have around 120k miles.
I am planning to rebuild the engine first, then turbo it, probably with the FMAX kit.
I want to keep a 10:1 CR and just use less boost. From what I have read, this is possible, but it just makes the window to tune a bit smaller. Is this worth it, or am i just asking for trouble? I notice a lot of you guys are using 9:1 pistons...
Old Apr 28, 2002 | 05:26 PM
Quaalude's Avatar
Default Re: fmax kit?? (Teen Heartthrob)
10:1 with moderate boost levels if u are tuned really good...this compression gives the motor more power when u are in off boost situations
with 9:1, u can use higher boost levels and is extra insurance
Old Apr 30, 2002 | 01:40 PM
Default Re: fmax kit?? (Quaalude)
but let's say the bottom end is completley built...will i have trouble running higher psi (10-17) on a 10:1 CR?
Or am i just asking for trouble?
GreatwhiteDC2
Nov 23, 2011 05:13 PM
jdm'dc2sc61
Apr 9, 2005 02:13 PM
mkell
Honda S2000
Dec 12, 2004 10:06 AM
XxRoCkMaNxNEOxX
Nov 14, 2003 06:46 AM
JICsube
Jan 18, 2003 11:42 AM
