How can I tell if I have a C5 head?
Old Aug 20, 2006 | 02:03 PM
JHN272's Avatar
Default How can I tell if I have a C5 head?
Just bought a built EG, thought I would just throw this question into this forum and see if any of you know...
I'm buying an intake manifold for it, i'm pretty sure the manifold for the B16A head is the same one that will fit on to a B18C5 head...and I'd like to make sure I actually HAVE a C5 head
100% sure the block is a B18C1 with a C5 crank, but I'm not sure whether or not it's the original head that was on with the original build (C5) or if it had been changed or what...
Is there anyway to tell the difference?
Old Aug 20, 2006 | 02:07 PM
paulzy's Avatar
the intake ports would look different. The ITR head will have different valve springs and cams as well.
the c1 and c5 crank are the same exact thing
Old Aug 20, 2006 | 02:11 PM
JHN272's Avatar
Default Re: (paul vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang &raquo;</TD></TR><TR><TD CLASS="quote">the intake ports would look different. The ITR head will have different valve springs and cams as well.
the c1 and c5 crank are the same exact thing</TD></TR></TABLE>
How would the intake ports look different?
If it's the original C5 head, it will have upgraded valve springs...this car was built in Houston by st00pid (Jason)
I'm pretty sure it's running GSR cams as well
EDIT: Just gave Jason a call, he can't remember if it was a B16 or a C5 head
But he's sure it isn't a GSR head, and I suppose it doesn't matter if the intake manifolds are the same for both
Old Aug 20, 2006 | 02:44 PM
dthug's Avatar
Default Re: (JHN272)
iirc the ports are the same for the c5 and b16 so it wouldn't matter
Old Aug 20, 2006 | 02:55 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (dthug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dthug &raquo;</TD></TR><TR><TD CLASS="quote">iirc the ports are the same for the c5 and b16 so it wouldn't matter</TD></TR></TABLE>
I've got both heads. Sitting side by side, you can tell the intake and exhaust ports on the C5 are a little bigger... smoother finish and etc. Whats the date on the head? If your wondering, there are numbers stamped on the exhaust side on the left hand side in little circles. The first numbers would be the year. 00, 97, etc.
the.hamburglar
Oct 9, 2006 01:36 PM
b16ferio
May 27, 2005 10:53 AM
ras
Apr 18, 2005 07:06 PM
Andre
Dec 30, 2004 04:32 PM
