b16a2 with blow by
Old Aug 20, 2006 | 12:10 PM
rainorshine81286's Avatar
Default b16a2 with blow by
i recently got a b16a2 swap into my 93 si and now after a couple of months a driving it i have some blow by problems my question is should i pull i out and rebuild it or should i buy a b16 longblock from hmotorsonline all the help i can get would be great ...im pretty new to this stuff
Old Aug 20, 2006 | 12:22 PM
philosofy1's Avatar
Default Re: b16a2 with blow by (rainorshine81286)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainorshine81286 &raquo;</TD></TR><TR><TD CLASS="quote">i recently got a b16a2 swap into my 93 si and now after a couple of months a driving it i have some blow by problems my question is should i pull i out and rebuild it or should i buy a b16 longblock from hmotorsonline all the help i can get would be great ...im pretty new to this stuff</TD></TR></TABLE>
blow by problems, what do you mean by blow by?
Old Aug 20, 2006 | 12:25 PM
Default Re: b16a2 with blow by (philosofy1)
piston rings not sealing
Old Aug 20, 2006 | 12:28 PM
philosofy1's Avatar
well if that's the case i would suggest a engine rebuild. if you keep it like that it's only going to get worse.
Old Aug 20, 2006 | 12:30 PM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">well if that's the case i would suggest a engine rebuild. if you keep it like that it's only going to get worse.</TD></TR></TABLE>
pulling the motor is more $ and more time if you ask me. you chould be able to ring it for a few hundred.
Old Aug 20, 2006 | 12:32 PM
philosofy1's Avatar
Default Re: b16a2 with blow by (JICEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">
pulling the motor is more $ and more time if you ask me. you chould be able to ring it for a few hundred.</TD></TR></TABLE>
it won't cost much if he knows how to pull the motor and ring it himself.
hell, he actually doesn't even need to pull the motor.
Old Aug 20, 2006 | 12:38 PM
strictly.business's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">blow by problems, what do you mean by blow by?</TD></TR></TABLE>
blow by is basically exhaust gases making it onto the ringlands and below the rings causing carbon build up, wear and loss of compression. its usually due to tired rings.
Old Aug 20, 2006 | 12:42 PM
philosofy1's Avatar
Default Re: b16a2 with blow by (strictly.business)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business &raquo;</TD></TR><TR><TD CLASS="quote">
blow by is basically exhaust gases making it onto the ringlands and below the rings causing carbon build up, wear and loss of compression. its usually due to tired rings.</TD></TR></TABLE>
thanks, but he already answered the question!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainorshine81286 &raquo;</TD></TR><TR><TD CLASS="quote">piston rings not sealing</TD></TR></TABLE>
Old Aug 20, 2006 | 04:02 PM
JICEK9's Avatar
hell, he actually doesn't even need to pull the motor.</TD></TR></TABLE>
thats what i said.
pulling the motor is more $ and more time if you ask me. you should be able to ring it for a few hundred.</TD></TR></TABLE>
i was compering 1.)pull the motor and replace the block and 2.)just ringing it.
and in my opinion, #2 is easier and cheaper.
Old Aug 20, 2006 | 04:14 PM
i apprecitate the help guys. just replacing the rings would be the cheap route but i feel like if i tear it all the way down then why not just rebuild it ... now i just gotta come up with some money to pay for it all
5200rpm209
Feb 13, 2010 11:43 PM
93sihatchy
May 16, 2007 05:42 PM
khodey
16
Jun 10, 2006 12:49 AM
Roky
Sep 15, 2004 06:22 PM
