Cleaning IACV question
Went to clean my IACV and couldn't get the coolant hoses off. So I just cleaned it while still attached to the coolant lines. Is this bad in any way? Thanks
Also can the MAP sensor be cleaned?
Depends on what you used to clean it with. Anyway, the easiest way to get the hose off is to use big pair of pliers (like what you should use to remove those metal clips). Take the pliers and put it on the end of the hose and rock it back and forth till it moves freely. Then just pull it right off
