b16 swap won't start.... maybe you can help?
Old Aug 19, 2006 | 07:33 PM
Wardell's Avatar
Default b16 swap won't start.... maybe you can help?
91 dx swapped to obd0 b16. has a brand new distributor
things checked so far:
wiring, all mpfi wiring checks out haven't run the vtec stuff yet but the wires are run off the ecu.
compression test, 180 or so across the board
checked spark at #1 cylinder, good spark
pulled the fuel rail, all injectors spraying
Cleaned grounds, tranny, thermostat, front motor and starter
ok, the motor will cough a bit then start for a second then die. if you give it gas it kills it trying to start. the battery light seems to be staying on.
any suggestions are welcome.
thanks for your help.
Old Aug 19, 2006 | 07:45 PM
Max Kling's Avatar
CEL's?
Firing order correct?
Timing correct?
What ECU?
Old Aug 19, 2006 | 07:54 PM
Wardell's Avatar
Default Re: (Max Kling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max Kling &raquo;</TD></TR><TR><TD CLASS="quote">CEL's? </TD></TR></TABLE> no, only light i am getting is battery light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max Kling &raquo;</TD></TR><TR><TD CLASS="quote">Firing order correct?</TD></TR></TABLE> yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max Kling &raquo;</TD></TR><TR><TD CLASS="quote">Timing correct?</TD></TR></TABLE> haven't been able to check it with a light yet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max Kling &raquo;</TD></TR><TR><TD CLASS="quote">What ECU?</TD></TR></TABLE> PW0 i believe
thanks
Old Aug 19, 2006 | 08:04 PM
88 rex's Avatar
Default Re: (Wardell)
Sounds like wiring to the dizzy.
Old Aug 19, 2006 | 08:09 PM
Wardell's Avatar
Default Re: (88 rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like wiring to the dizzy.</TD></TR></TABLE>
why do you think that?
Old Aug 19, 2006 | 09:27 PM
88 rex's Avatar
It's easy to mess up that wiring. I did it and I had directions
Mine was doing almost exactly what yours is doing. I had spark and fuel and compression but it turns out I goofed and messed up a few wires.
Old Aug 20, 2006 | 11:18 AM
Wardell's Avatar
anyone have a pic of the map sensor area on their swap? i need to see if i have the vaccum lines right.
thanks
Old Aug 20, 2006 | 02:40 PM
DC_RaceR's Avatar
https://honda-tech.com/zerothread?id=1442626
Old Aug 23, 2006 | 07:08 PM
Wardell's Avatar
Default Re: (DC_RaceR)
ok this thing has some kinda fuel issue i think. If i spray some starting fluid into it when starting it starts up. this leads me to think its not getting fuel. i have 50 psi at the fuel rail. i put a injector noid on the #1 injector plug and when i crank the light is very faint.. the light gets bright for a second when the motor seems to catch.
aside from this fuel issue which i am currenlty stumped on. does anyone have a pic of the round distributor plug? i need to know what wires go where. i had to de-pin a square connector that was on the dx harness and got a round connector from a different dx harness.
Old Aug 23, 2006 | 07:35 PM
Wardell's Avatar
anyone help me out?
Old Aug 23, 2006 | 08:01 PM
88 rex's Avatar
So once its started it runs and idles fines?
Old Aug 24, 2006 | 04:06 AM
Wardell's Avatar
No, it runs poorly, but it can run a bit if i spray it.
Old Aug 24, 2006 | 08:43 AM
sauceja's Avatar
Then you should double check your wiring to your injectors. Sounds like a bad splice, solder, butt connector or however you hooked them up.
Old Aug 24, 2006 | 03:17 PM
Wardell's Avatar
Default Re: b16 swap won't start.... maybe you can help? (Wardell)
mother fugger.... how does the resistor box work exactly? could that be faulty?
on another note i checked the timing today, i am 100% sure the timing is on, and its on the right stroke.
whats the precedure for checking injector voltage? maybe i could cut it down to one or two misbehaving...
thanks for all the input thus far
Old Aug 25, 2006 | 07:19 PM
psikotc's Avatar
when i swapped my b16 into my 91 hatch, i had a similar problem. found out that the injectors themselves were bad not the wiring to them. swapped the injectors from my old a6 (they are the same) and it fired up and ran like a champ. retrace the wiring and if you still have the same problem, check the injectors. just my .02.
Old Aug 25, 2006 | 07:49 PM
Wardell's Avatar
Default Re: b16 swap won't start.... maybe you can help? (p.s.i.kotic)
thanks for the added ideas... anyone ever have a resistor box crap out?
Old Aug 25, 2006 | 08:10 PM
DC_RaceR's Avatar
Mine almost did the same thing... But it might help..
My engine starts rev up to 5000k and die.
I had a bad TPS. and check the connector on the IACV and MAP sensor.
Double check all you vaccum lines
v8killaz
Nov 6, 2008 01:36 PM
4drsleeper123
Aug 27, 2005 07:05 PM
bob06
Mar 24, 2005 06:55 PM
RussHondaCRXVtec
Dec 16, 2003 09:37 PM
KLN
Dec 30, 2002 11:56 PM
