car overheats only on highway.??
Old Aug 19, 2006 | 07:25 PM
97grnrs's Avatar
Default car overheats only on highway.??
my ls turbo runs great but every time i get on the highway for more than 15 min goin an average of 60 mph my car will overheat, temp goes to bout 3/4 of the way up.. i can drive around town all day and not have any problems but when im on the highway it will always do it.. i am using a half size civic rad and i had 2 fans on it but that made no diff so i went back to just one. there is no air in the system and i dont run a full thermostat. it always open basically. i cut the middle out of the stock thermo stat so its always open. could that have anything to do with it?
Old Aug 19, 2006 | 07:34 PM
komat's Avatar
Default Re: car overheats only on highway.?? (97grnrs)
could be since the coolant cant be cool down enough before it goes back into the motor
Old Aug 19, 2006 | 07:37 PM
97grnrs's Avatar
Default Re: car overheats only on highway.?? (komat)
thats sort of what i was thinkin.. maybe coolant is moving too fast and cant stay in rad long enough to cool properly on highway. anyone else think so ?
Old Aug 19, 2006 | 07:47 PM
kala4nia's Avatar
i would put a working thermostat in it.
Old Aug 19, 2006 | 09:28 PM
boostismycrack's Avatar
E-thug
Default Re: (kala4nia)
check ur headgasket.
Old Aug 19, 2006 | 10:13 PM
jsw_1986's Avatar
Default Re: (boostismycrack)
I had the same problem in my civic.... in my case it was that the radiator was clogged up. I changed it out then turbo'd the car and never had a problem.
Old Aug 19, 2006 | 10:25 PM
scttydb411's Avatar
you also need to check and see if you have the fans wired to blow in the correct direction. if it is on the engine side of core and wired as a pusher it will be fighting the air coming into the core...common mistake if aftermarket fans installed.
Old Aug 19, 2006 | 11:31 PM
F20Cteg's Avatar
Default Re: (scttydb411)
Check the coolant level first
Old Aug 19, 2006 | 11:34 PM
SFWD 1934's Avatar
Default Re: (F20Cteg)
Is the car running funky on the AFR's? If so, I would check the headgasket, could be shot somewhere due to lifting of the head. Otherwise do what these other guys are saying, make sure if you set the fans up, the one on the front of the car is a "puller" not a "pusher". Make sure that the inside fan is a "pusher."
Jason
Old Aug 20, 2006 | 07:57 AM
97grnrs's Avatar
Default Re: (SFWD 1934)
fans are all right.. coolant is good and bled well. i put in a working thermostat today so i guess ill try that and see what happens..
Old Aug 20, 2006 | 03:45 PM
psikotc's Avatar
Default Re: (jsw_1986)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsw_1986 &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem in my civic.... in my case it was that the radiator was clogged up. I changed it out then turbo'd the car and never had a problem.</TD></TR></TABLE> had the same problem, and the same solution.
Old Aug 21, 2006 | 11:47 AM
Finland's Avatar
Default Re: (p.s.i.kotic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p.s.i.kotic &raquo;</TD></TR><TR><TD CLASS="quote"> had the same problem, and the same solution. </TD></TR></TABLE>
had the same problem on an old 87 civic I had a long time ago, same solution
It equates to a flow restriction. If your radiator isn't clogged, perhaps the restriction is elsewhere.
slow2002gt
Jun 25, 2011 11:47 AM
saikou
Jul 7, 2008 07:20 PM
Nickbee
Oct 19, 2007 03:28 AM
LoooseGSR
Jul 15, 2003 10:49 PM
One Bad GeeSeeR
Dec 4, 2002 05:08 AM
