How To Change Rear Main Oil Seal
Old Aug 19, 2006 | 04:53 PM
Fatty_1775's Avatar
Default How To Change Rear Main Oil Seal
Any instructions on how to change the rear oil main seal on a b16? Does the transmission have to be removed? Thanks.
Old Aug 19, 2006 | 06:00 PM
_BEN_'s Avatar
Default Re: How To Change Rear Main Oil Seal (Fatty_1775)
Yes the transmission and the flexplate / flywheel will also have to be removed.
Old Aug 20, 2006 | 10:43 AM
postman's Avatar
Default Re: How To Change Rear Main Oil Seal (_BEN_)
remove tranny. remove flywheel, remove seal, lube inside new seal, install, put back together
Old Aug 20, 2006 | 02:12 PM
FIGARILA's Avatar
Default Re: How To Change Rear Main Oil Seal (postman)
if you read the OEM manual it recomends that the seal be .020 to .015 from touching the bottom of the hole. I don't know why
Old Aug 21, 2006 | 07:48 AM
Fatty_1775's Avatar
Default Re: How To Change Rear Main Oil Seal (Heron of Alexandria)
for the rear main oil seal, do I need to buy anything else other than the seal? Other gaskets around it or so that should be replaced while doing it? Thanks.
Old Aug 21, 2006 | 09:20 AM
_BEN_'s Avatar
Might as well change your oil and gear box fluid while you are at it. Unless you have just changed it.
You are going to need some tall jackstands and a third jack to support the engine.
A clutch alignment tool would be something nice to have as well.
Pretty much everything you will need for a clutch job except for a new clutch/flywheel.
Old Aug 21, 2006 | 10:28 AM
Fatty_1775's Avatar
is the rear main seal also called the crankshaft seal?
Old Aug 21, 2006 | 07:00 PM
SteveoBA8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatty_1775 &raquo;</TD></TR><TR><TD CLASS="quote">is the rear main seal also called the crankshaft seal?</TD></TR></TABLE>
yes, crankshaft rear seal
Old Aug 22, 2006 | 01:19 PM
Fatty_1775's Avatar
Default Re: How To Change Rear Main Oil Seal (SteveoBA8)
is there anything else that is advisable to change while changing the rear main seal?
Old Aug 22, 2006 | 10:37 PM
Fatty_1775's Avatar
ttt
Old Aug 23, 2006 | 03:23 AM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatty_1775 &raquo;</TD></TR><TR><TD CLASS="quote">is there anything else that is advisable to change while changing the rear main seal?</TD></TR></TABLE>
if that is the only seal that is leaking then nothing else needs to be replaced.
rogue420
14
Jul 18, 2010 05:44 PM
ch0g0nda
Jul 28, 2008 12:04 PM
folta2169
Sep 3, 2007 01:50 PM
0ptimus prime
12
Jul 18, 2004 01:29 PM
chhuong
Oct 2, 2002 09:44 AM
