Itr tranny and GSR which one???
I just got a type r tranny from a friend for $900 he got it from the acura dealership here in bakersfield two years ago for $2200 he still has the invoice from acura... well I have a turbo gsr 289whp @8lbs but the gsr tranny works fine no grinds but I want lsd for better 60fts I want to take out the differential from the Itr and put it in my gsr. but the Itr tranny is like new. but I want lsd and the gsr longer gears. or should I just put the Itr tranny in? how much power can the Itr tranny take? please help me!!!!
i find the gsr gears to be way to short, itr are even shorter.
I would say try and put the itr lsd in the gsr trans im not sure if itll drop in tho, im sure someone else would know more on that.
On another note, the ITR lsd cant handle more than 300whp, it technically can if you baby it, but if you doing hard launches itll **** on you pretty quick. I picked up an OBX LSD against the better judgement of the H-T crowd and i havent regretted it at all, re-tq the casing bolts, drops right into the gsr trans, hard launch all day and it hook right up [300whp] its only like $380 and has a lifetime warranty thru obx but we know how they are....
Now im looking into the LS final drive mod
im not sure if its 300crank or wheel hp, i think its wheel...
But like i said itll hold up if you baby it, i need to make that disclaimer before the H-T bandwagon arrives saying "oh im running the ITR with 400 blah blah" yeah those people arent hard-launching, so their lsd is still in one piece.
Its not recommended for over 300whp, unless you plan to launch very carefully, but there are people making 300+ running the itr lsd..... i wouldnt want to put all that $$ and time into buying and installing the lsd just to worry about it on every launch
i say sell the itr trans, make a profit, buy an obx or if you have the cash quiafe lsd and call it a day
the itr diff will hold way more than 300hp my firend has made over 500whp one for 3 years and beat the **** out it and its still good. if you do want to use the itr diff in the gsr tranny then you got to swap the final drive.... i would stick with the gsr tranny sell the gsr and buy a quife. quife has a lifetime race warenty
wow 300hp on an itr thats rediculous, drivers kill trannys and lsd's. The ITR diff can take some descent abuse just search around some of the fastest cars are still runin a itr lsd street cars anyways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swapit »</TD></TR><TR><TD CLASS="quote">my type r lsd is workin greeeat!!!!!!!!!!just went 10.57 last night with a 1.68 60ft.and its been goin strong for a couple years now
well i stand correct
i wasnt stating it as fact i just read alot of poeple who go 300+ choose quaife or other aftermarket lsds opposed to the ITR cause it cant handle the pressure
they must just suck at driving
</TD></TR></TABLE>well i stand correct
i wasnt stating it as fact i just read alot of poeple who go 300+ choose quaife or other aftermarket lsds opposed to the ITR cause it cant handle the pressurethey must just suck at driving
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">i find the gsr gears to be way to short, itr are even shorter.
On another note, the ITR lsd cant handle more than 300whp, it technically can if you baby it, but if you doing hard launches itll **** on you pretty quick. </TD></TR></TABLE>
Shortest geared tranny is going to accelerate the quickest everytime. Get a better suspension/traction setup and go with the ITR tranny.
People run open diff and stock axles running 10s. It's all in the launching of the car. And for the record....it can handle way more than 300whp if driven properly.
If you are worried about the cruising rpm, get a set of LS 5th gears and put them in the ITR tranny.
you should use the itr tranny!!! i used a jdm itr tranny on my setup with the 4.78 f/d and it managed to treat me well with 527whp400tq
daily driven and tracked on slicks
HondaTeKnology
Mar 20, 2008 11:40 AM
