surging
Old Aug 17, 2006 | 08:54 PM
JRTegman's Avatar
Default surging
ok guys so my friends car has a problem with surging
it will idle fine for a few minutes, but then it will surge up and down after a while
valves, were recently replace and timing belt, tensioner and tensioner bolt. i have no idea what would make it do this at least not the idle fine for a while then do it
Old Aug 18, 2006 | 05:44 AM
dohctorjeh's Avatar
Default Re: surging (JRTegman)
is ur engine light on? if so read the code and go from there. if not check for a intake manifold leak or vacuum leak
Old Aug 18, 2006 | 09:34 AM
JRTegman's Avatar
Default Re: surging (lbx)
he put on a hondata IM gasket could that be causing a leak and causing this? maybe a faulty gasket?
AudioFunk
Feb 7, 2015 11:40 AM
si_motor_spt
Nov 14, 2008 03:14 PM
Out of every "game"
Feb 8, 2006 01:12 PM
1 speedstar
Apr 16, 2003 05:25 PM
Prevail
Feb 28, 2003 07:19 AM
