turbo single cam or all motor dohc
Old Aug 17, 2006 | 07:45 PM
Slowass2dr's Avatar
Default turbo single cam or all motor dohc
well i just bought a 1990 civic wagon with the rt4wd 6spd just wanted to know what u guys think would best a sohc vtec keeping the rt4wd system with a mild turbo kit or swap a ls motor in it? they are both aroungd the same price for me and i think the the sohc vtec with turbo and rt4wd would be funner what do u guys think?
Old Aug 17, 2006 | 07:47 PM
EF_ST@TUS's Avatar
LS VTEC ALL THA WAY BABY!!!
or turbo ls.....
DOHC's spool faster
Old Aug 17, 2006 | 09:19 PM
bag's Avatar
bag
Default Re: turbo single cam or all motor dohc (Slowass2dr)
turbo the sohc dont forget to get a head stud kit..4wd,200whp,turbo,
also check this video http://www.draglab.com/media/ShitBox%20A6.wmv
Old Aug 17, 2006 | 11:09 PM
661rex89si's Avatar
sohc turbo cheaper and way more rewarding when your leaving dohc in the dust. but either way you slice it. it will work out both ways but boost is more fun
Old Aug 18, 2006 | 01:14 AM
davens's Avatar
You have a plan for getting that LS to work with your 4wd?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">DOHC's spool faster</TD></TR></TABLE>
Care to explain that one?
Old Aug 18, 2006 | 03:57 AM
ludesrv's Avatar
Default Re: turbo single cam or all motor dohc (davens)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">You have a plan for getting that LS to work with your 4wd?
Care to explain that one?</TD></TR></TABLE>
Good post right there. The LS won't work with that 4wd D series tranny. You would need a B to D plate, but then it might push the tranny out of alignment and make the 4wd not work still (rear driveshaft might get pushed out of allignment).
And the DOHC spools faster comment...where the hell did you get that one from? Don't beleive everything everyone tells you.
Old Aug 18, 2006 | 08:27 AM
Slowass2dr's Avatar
naw if i go single and turbo i keep the 4wd but if i choose l the i have to eliminate it
Old Aug 18, 2006 | 02:56 PM
StorminMatt's Avatar
Default Re: turbo single cam or all motor dohc (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">And the DOHC spools faster comment...where the hell did you get that one from? Don't beleive everything everyone tells you.</TD></TR></TABLE>
A larger displacement motor is going to spool faster due to greater exhaust flow.
Old Aug 18, 2006 | 03:20 PM
davens's Avatar
Default Re: turbo single cam or all motor dohc (StorminMatt)
If you were using the same sized turbo on both...but, is that a good idea?
Old Aug 18, 2006 | 03:32 PM
GRANDE7652's Avatar
I personally prefer built NA but without the 4wd you better off with a hatchback/crx.So just get a turbo and keep the 4wd
Old Aug 19, 2006 | 12:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">If you were using the same sized turbo on both...but, is that a good idea?</TD></TR></TABLE>
It depends. A smaller turbo will not make as much peak HP as a larger one. But it will be more daily drivable.
Old Aug 19, 2006 | 06:45 PM
davens's Avatar
I realize that. I'm not going to dig out specs on turbo kits, but I assume the turbo you typically see on a d-series kit will be smaller than what you find in B-series kit.
But you're specifically talking about B vs D and the displacement advantage.
What if we're talking D vs D, like D16a6(sohc) and D16a9(dohc)? Does a "DOHC spool faster" than a sohc of the same displacement?
Old Aug 19, 2006 | 10:03 PM
Slowass2dr's Avatar
Default Re: (davens)
lol well does it? can anyone awenser
Old Aug 19, 2006 | 10:39 PM
EF_ST@TUS's Avatar
Yea I wanna know if what I was right....
Old Aug 20, 2006 | 06:32 AM
blah13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost_in_a_world_so_cold &raquo;</TD></TR><TR><TD CLASS="quote">LS VTEC ALL THA WAY BABY!!!
or turbo ls.....
No, a larger displacement motor will spool a turbo faster, dohc vs sohc wont matter for turbo spool aside from cam profile differences. But then its not exactly sohc vs dohc. A cammed sohc would spool a turbo <U>slightly</U> faster than a stock one. But were talking very minimal. Get a turbo for your application, which for you I would suggest a smaller turbo with quick spooling if your gonna rock the rt4wd, more power sooner ftw.
Plus if your not gonna build the motor your gonna sit around 200hp, which any small turbo will be capable of making. 8-10psi.
Old Aug 20, 2006 | 08:18 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
A larger displacement motor is going to spool faster due to greater exhaust flow.</TD></TR></TABLE>
Depends on the turbo and the application.
Old Aug 20, 2006 | 10:04 AM
1991civicsi's Avatar
http://www.homemadeturbo.com
Old Aug 20, 2006 | 11:23 AM
CRX Toad's Avatar
I say either. Both would be fun.
omar256hxc
Sep 30, 2006 02:21 PM
ek9child
Apr 9, 2006 04:06 PM
ek9child
Apr 9, 2006 01:53 PM
spyderracing
11
Jul 14, 2004 04:12 AM
b16coupe93
22
Sep 7, 2002 04:11 PM
