90 CRX Si wont start
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bnoland »</TD></TR><TR><TD CLASS="quote">I have a 90 CRX and it will run but I have to bump start it. When I turn the key nothing happens. I didn't find any blown fuses.. what else is there to check? Thanks</TD></TR></TABLE> starter or starter selenoid is bad use a dmm and check voltage drop from battery to the starter that is the most likey cause if you can push start it but no start with the keys
that is exactly what happened to my car when i swapped it. i didnt think was a blown fuse either until there was daylight, it was the ignition fuse in the box on the shock tower under the hood. its one of the big weird lookin ones, ill go snap a pic real quick.
its the big red one, hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamRedline89Hatch »</TD></TR><TR><TD CLASS="quote">that is exactly what happened to my car when i swapped it. i didnt think was a blown fuse either until there was daylight, it was the ignition fuse in the box on the shock tower under the hood. its one of the big weird lookin ones, ill go snap a pic real quick.
its the big red one, hope this helps</TD></TR></TABLE>
Checked that one.. it wasnt it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFlCrx »</TD></TR><TR><TD CLASS="quote"> starter or starter selenoid is bad use a dmm and check voltage drop from battery to the starter that is the most likey cause if you can push start it but no start with the keys </TD></TR></TABLE>
I will check this tomorrow and update with what I find.
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFlCrx »</TD></TR><TR><TD CLASS="quote"> starter or starter selenoid is bad use a dmm and check voltage drop from battery to the starter that is the most likey cause if you can push start it but no start with the keys </TD></TR></TABLE>I will check this tomorrow and update with what I find.
Thanks
i have the same no start prob too. the car died while i was driving it but only starts when its jump charged anyway i think it might be that red fuse problem. do you know if i can buy one at a local parts store i dont see any on ebay....
I found it.. it turns out that the wire that tells the solinoid that you are turning the key has a ground on it somewhere. I took a wire and put it to where that plug goes and touched it on the battery post and poof.. it started. So I will ether run a new wire from the solinoid to the ignition ( replaced the ignition so thats not the problem ) or I will just run a wire to a push button and have a push button start.
I had the same problem, fixed it with a relay like this.
You will need a relay:
http://www.radioshack.com/prod...earch
or you can get a relay + socket for cheaper on ebay(socket makes cleaner install)
http://cgi.ebay.com/12-Volt-30...wItem
you will also need:
1.Wire, i used 12 gauge should be able to use smaller wire
2. Connectors: 4 female disconnects, the larger size from radioshack, only need 1 of these if you have a socket. 2 spade connectors, 1 to fit the battery post or a direct power sorce, the other will need to be big enough to fit a clean ground.
3. Tools, a wire crimper/stripper/cutter
Here is what I did.
1. Ran the signal wire to post 85 on the relay
2. Measured/cut wire to run a line from post 86 on relay to a clean ground on chasis.
3. Measured/cut wire to run a line from post 87 on relay to the starter connection, where signal wire originally was.
4. Measured/cut wire to run a line from the battery terminal to post 30 on the relay. Use a fuse here if youw anna be safe, I didn't .
Very easy job, I did it with no relay knowledge just researched and found out how myself.
you will also need:
Here is what I did.
smokez187
Aug 10, 2007 11:35 AM
