golden eagle fuel rail and precision injectors
Old Aug 17, 2006 | 04:55 PM
redboost10's Avatar
Default golden eagle fuel rail and precision injectors
i was just wondering how everyone goes about drilling out the fuel rail so the head of the precision injectors fits in it. thank you
Old Aug 17, 2006 | 04:57 PM
turbotime's Avatar
you dont need to drill it, its oversized already just gotta push them in there, may wanna lube the orings, i ripped one getting it into the rail cause it caught...
but there is no need to drill. (i run ge rail and precision ) its a tight fit, but theyll go in
Old Aug 17, 2006 | 05:04 PM
Danny_EJ's Avatar
Did you get the sport compact injectors or the ones designed for a DSM?
I have a Golden eagle rail and Precision Sport Compact injectors - lube the orings with light oil and press on they fit perfect.
Old Aug 17, 2006 | 05:05 PM
redboost10's Avatar
Default Re: (Danny_EJ)
i dont know what precision injectors i got, i know they are 1000cc because i got them flow tested, and there is no way that the injector is going into the fuel rail
Old Aug 17, 2006 | 05:11 PM
turbotime's Avatar
mine were sport compact and they definitely fit, even though i didint think they would
youd be surprised, take a pic if they are that much bigger....
Old Aug 17, 2006 | 05:20 PM
redboost10's Avatar
Default Re: (turbotime)
i just took some pics, let me get them on here
Old Aug 17, 2006 | 05:46 PM
redboost10's Avatar
Default Re: (tgh99si)
alright, im sure i can get the injector in the rail if it only goes as far as the rubber o-ring, but looking at my old rc eng injectors, they go in a lot further, so the o-ring is more in the injector. heres some pics
i can get it in with the o-ring, but it will stop at the black plastic lip thing
on this last pic, i took the o-ring off so you can see how far it will go in if i put it in with the o-ring, is that enough?
Old Aug 17, 2006 | 06:37 PM
NightRiderS2K's Avatar
In-N-Out Burger
No matter what you will need an O-ring. Without one, it will leak for sure.
Anyhow, you may have luck looking for a smaller O-ring from a hardware store. And as stated before, it doesn't hurt to use some lube to fit it in the rail. Goodluck!
Old Aug 17, 2006 | 08:25 PM
redboost10's Avatar
Default Re: (NightRider-gsR)
i know an o-ring is needed, i just took that pic so you can see that it does fit in there. i am going to find some smaller o-rings and see if i can lube it up and fit them in there.
Old Aug 17, 2006 | 08:38 PM
Redwidow's Avatar
im sure thats all they go...same with my rodchestors...aka precision
Old Aug 17, 2006 | 10:18 PM
B18C1CYA's Avatar
Default Re: golden eagle fuel rail and precision injectors (tgh99si)
they look like the dsm ones
Old Aug 18, 2006 | 06:09 AM
redboost10's Avatar
Default Re: golden eagle fuel rail and precision injectors (B18C1CYA)
i got some thinner o-rings and couldnt get it to work, so i milled the holes out to a little under what the diameter of the injector head is and used the fatter o-rings, fits snug. thanks guys
Old Aug 18, 2006 | 06:52 AM
turbotime's Avatar
glad it worked out i think its like above stated cause you got the dsms, the sport compact require no mods
Old Aug 18, 2006 | 06:58 AM
redboost10's Avatar
it was no problem, but there was no way those were going to fit in there.
Old Aug 18, 2006 | 07:05 AM
Danny_EJ's Avatar
Those are DSM style. Glad it worked out for you!!
Old Aug 18, 2006 | 07:08 AM
redboost10's Avatar
they use the same clips i found out, haha. just a bigger head
airwalk07143
Dec 30, 2008 05:56 AM
MotorMatrix.com
Feb 18, 2003 07:09 PM
MartGSR
Jul 21, 2002 04:50 PM
