piston rings scraped the cylinder sleeve...
Old Aug 17, 2006 | 04:13 PM
jennsGSR's Avatar
Default piston rings scraped the cylinder sleeve...
ok, so when we changed the piston rings, one of the piston rings slightly popped out, and slightly barely, scratched the cylinder wall, now... if i rehone it, and it doesnt fix the problem, would anything be detrimental to me driving my car that way? i know i could buy a new sleeve, but sheesh, im already doin a complete engine overhaul. any suggestions? thanks..
Old Aug 17, 2006 | 04:21 PM
unknown0001's Avatar
Default Re: piston rings scraped the cylinder sleeve... (jennsGSR)
Did you hone out the cylinder walls before you put in the new rings? if it's a scuff then it wont harm it as the rings will seal with the cylinder wall crosshatch and won't be noticible in a few km.
I wouldn't worry about it, if you really are worried then do a quick hone on that cylinder and install the rings properly again
Old Aug 17, 2006 | 04:41 PM
jennsGSR's Avatar
Default Re: piston rings scraped the cylinder sleeve... (Mr.RHTuner)
awesome. yea we hones out the walls the first time. and we will try to do it again. so that makes me feel better. thanks..
Old Aug 17, 2006 | 06:12 PM
Dartanian's Avatar
If, after honing, it is still deep enough to catch your fingernail, it would be a good idea to get it over bored.
1320london
Engine Machining & Assembly
Sep 17, 2016 12:00 PM
qazaq
Jul 14, 2007 04:20 PM
beemaz
Apr 21, 2004 07:40 PM
myhatchrips
Nov 9, 2003 12:46 PM
filetofit
Sep 24, 2002 04:03 PM
