alternator question
Old Aug 17, 2006 | 08:31 AM
em Dot's Avatar
POOPCheeks
Default alternator question
so i need to replace my alternator and i really dont want to take the axle out to change so i was wondering if any one has taken out the brake booster to take the alternator out? also the car is a stock crx si thanks
Old Aug 17, 2006 | 08:41 AM
thesmogman's Avatar
Default Re: alternator question (em Dot)
Just jack up the drivers side front and it will fall out the bottom.
You might have to remove the bottom Alt.bracket too.
Old Aug 17, 2006 | 08:42 AM
Loserkidwac's Avatar
I never had to take off either, I just turned the wheel or something and was able to sneak it out past the axles, it comes out 1 certain way but it works, just mess around with it, i don't think i even had to take the lower brackt off...
Old Aug 17, 2006 | 08:47 AM
SVOboy's Avatar
Default Re: alternator question (Loserkidwac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">I never had to take off either, I just turned the wheel or something and was able to sneak it out past the axles, it comes out 1 certain way but it works, just mess around with it, i don't think i even had to take the lower brackt off...</TD></TR></TABLE>
I just had to move the plastic piece out of the way in the wheel well.
Old Aug 17, 2006 | 08:53 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: alternator question (SVOboy)
same, axle does'nt need to come out
have fun with that.. i decided to take out my intake manifold which just made more problems, but shrug
Old Aug 17, 2006 | 09:03 AM
Default Re: alternator question (GarageAlchemist)
With my LS swap i can pull it up out the top and only have to remove the up alt braket
Old Aug 17, 2006 | 10:13 AM
em Dot's Avatar
POOPCheeks
cool thanks guys im goin to do it now
Old Aug 17, 2006 | 02:57 PM
marquisdee1018's Avatar
I had to take my brake booster out. I just replaced mine yesterday.
bravo76
Jan 17, 2007 08:54 AM
PnkRokCountryboy
Aug 1, 2006 12:06 PM
X-Static
Sep 9, 2004 10:46 PM
EF4lyfe
Jan 17, 2004 09:30 AM
SilverDc2
Jun 10, 2003 07:53 PM
