oil fill bolt is stuck.. can i fill anywhere else 91 STD
Old Aug 17, 2006 | 07:55 AM
GarageAlchemist
Guest
Posts: n/a
Default oil fill bolt is stuck.. can i fill anywhere else 91 STD
wow.. ok after replacing axles, clutch, mounts, etc etc.. the last frigging bolt on this project spree is the damm refill bolt on the tranny.. it won't budge..
i can't use a breaker bar cuase of where the bolt is, so its wrench only, box end..
can i pop out an axle and fill it in there.. ug.. help !!
Old Aug 17, 2006 | 08:06 AM
crxnj's Avatar
Default Re: oil fill bolt is stuck.. can i fill anywhere else 91 STD (GarageAlchemist)
i honestly never use and never have used the "refill bolt" ..you can fill it at where the reverse light sensor is...
Old Aug 17, 2006 | 08:16 AM
bks84's Avatar
Loved
unbolt the 100mm bolt that holds the speedo in... get a long funnel and fill it that way.
Old Aug 17, 2006 | 08:17 AM
Honteggie's Avatar
pull the speed sensor out. one bolt, take the sensor out and fill it there. Thats how I do it always just because its easier to get to.
Old Aug 17, 2006 | 08:18 AM
Honteggie's Avatar
Damn 4sd4dr just barely beat me to it. He posted while I was typing. Lol.
I can add something though. Since you cant get the fill bolt out, you won't know when to stop filling. I always just throw in exactly 2 quarts and I have never had a problem.
Old Aug 17, 2006 | 08:28 AM
turbohappy's Avatar
I hate to ask this, but did you try the trick where you put another wrench on the end of the first wrench so you get twice as much torque on the bolt?
Old Aug 17, 2006 | 08:35 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: oil fill bolt is stuck.. can i fill anywhere else 91 STD (turbohappy)
i was looking for anything, its an std.. you guys sure it has one.. any pics of it, or where its located... i don't know if the 4speed tranny has it in..
but thanks a lot guys, this looks promissing
Old Aug 17, 2006 | 08:45 AM
90sedan's Avatar
Yes the 4spd tranny has a speed sensor as well.
Old Aug 17, 2006 | 08:46 AM
GarageAlchemist
Guest
Posts: n/a
k, just checked out found 1 sensor, has 2 wires looks like its in the gear box
but its not 100mm or 10mm if that wa sa mistype, its slightly bigger than 17mm, prob 18 or 19..
is that what your talking about.. theres a lot a very very small vacom tube that dumps off, it would take bloody long but would that work as well..
thanks
Old Aug 17, 2006 | 09:35 AM
Honteggie's Avatar
The speed sensor is on top of the tranny towards the back. It will be in the casing right above the diff area(the axles). It is a 10mm bolt that holds down a little lock for it. There is a cable that is clipped into the middle of it, this is what drives the speedometer. If your speedo works, then it is definately there.
Old Aug 17, 2006 | 09:49 AM
Dave_Darling's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohappy &raquo;</TD></TR><TR><TD CLASS="quote">I hate to ask this, but did you try the trick where you put another wrench on the end of the first wrench so you get twice as much torque on the bolt?</TD></TR></TABLE>
+1!
Get yourself a nice long box-end wrench with an end that will fit over the end of the first wrench. Hook it over the first one, pull for all you're worth, and maybe even try whacking it with a hammer.
Moral of the story: Never overtighten that plug!!
--DD
Old Aug 17, 2006 | 10:04 AM
SiMateoAko's Avatar
I tried to do this by pulling the speed sensor. After a day of cursing, I just removed the back-up light sensor and filled it that way.
My speed sensor wouldn't budge.
for back-up light sensor refill
Old Aug 17, 2006 | 11:01 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (SiMateoAko)
i'm not sure which one i used, but i tried the one in back first, with tyhe 10mm and the clip.. that was a pita.. and filled VERY slowly.. and hard to get to.. aka waste of my time
then i tried my first idear, the switch in front with 2 wires, it's a 19mm wrench, and that worked great. Just flushed 4 qtrs threw the bastard, that thing is cleannnnn.
Old Aug 17, 2006 | 01:20 PM
B6tizzleHatch's Avatar
Default Re: (GarageAlchemist)
17mm wrech + rubber mallet = problem solved!
Old Aug 17, 2006 | 07:04 PM
Crackback's Avatar
Default Re: (B6tizzleHatch)
Couldnt have said it better myself
Old Aug 18, 2006 | 05:51 AM
paopao's Avatar
Default Re: (Crackback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crackback &raquo;</TD></TR><TR><TD CLASS="quote">17mm wrech + rubber mallet = problem solved!
Couldnt have said it better myself </TD></TR></TABLE>
Yeah, this has always worked for me as well. You can always kick the **** out of the wrench too.
Old Aug 18, 2006 | 07:31 AM
ProjectDarkBlack's Avatar
Default Re: (paopao)
I use a 27mm for a breaker bar. Chrome on chrome tends to cause some extreme slippage (especially with oil involved) so be carefull
Old Aug 18, 2006 | 10:54 AM
Tippyman's Avatar
I've always used the speed sensor. If it's already out, it's easier for me cause it's at a better angle than the fill hole.
Old Aug 18, 2006 | 11:04 AM
Default Re: (Tippyman)
pretty sweet tip yo, I never thought of that. Ive always had something really annoying to try and refill the transmission
Old Aug 18, 2006 | 11:23 AM
4thgenhtch's Avatar
Default Re: (ProjectDarkBlack)
Next time just fill through the axle hole before putting the last axle in
stevevang
Mar 27, 2016 04:46 AM
doom26464
Jun 18, 2008 07:10 PM
RCautoworks
Feb 16, 2003 11:16 PM
gumbybum
Jan 28, 2003 09:40 PM
hellas
Jan 21, 2003 12:33 PM
